Voxel Custom firmware build for R9000/R8900 v. 1.0.4.71HF
Voxel
Part of the Furniture
Continuation of:
https://www.snbforums.com/threads/custom-firmware-build-for-r9000.40125/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-69hf.85492/
https://www.snbforums.com/threads/custom-firmware-build-for-r9000-r8900-v-1-0-4-70hf.86329/
New version of my custom firmware build: 1.0.4.71HF.
Changes (vs 1.0.4.70HF):
1. Toolchain: binutils version is upgraded 2.40->2.41.
2. Toolchain: Go is upgraded 1.21.0->1.21.3.
3. curl package is upgraded 8.2.1->8.4.0 (fixing CVE-2023-38545, CVE-2023-38546).
CVE-2023-38545: high severity vulnerability (!)
CVE-2023-38546: low severity vulnerability​
4. netatalk package is upgraded 3.1.15->3.1.18 (fixing CVE-2022-22995, CVE-2023-42464, CVE-2022-23121, CVE-2022-23123).
(score 9.8, Critical)​
5. OpenSSL v. 1.1.1 package is upgraded 1.1.1v->1.1.1w (fixing CVE-2023-4807).
(score 7.8, High, but actually is not related to router firmware)​
6. ethtool package is upgraded 6.4->6.5.
7. ipset package is upgraded 7.17->7.19.
8. proftpd package is upgraded 1.3.8->1.3.8a.
9. coreutils package (sort/gnu-date) is upgraded 9.3->9.4.
10. sysstat package is upgraded 12.7.2->12.7.4.
11. zlib package is upgraded 1.2.13->1.3.
12. unbound package (used in stubby) is upgraded 1.17.1->1.18.0.
13. dbus package is upgraded 1.14.8->1.14.10.
14. jq package is upgraded 1.6->1.7.
15. iperf3 package is upgraded 3.14->3.15.
16. less package is upgraded 633->643.
17. minidlna: libjpeg 9e package is replaced with libjpeg-turbo 2.1.5.1.
18. Kernel: Linux kernel patch to fix build with binutils >= 2.41.
19. Host tools: upgrade xz to 5.4.4.
20. Host tools: upgrade mpfr to 4.2.1.
21. Host tools: add Python3 patch to ipkg-utils.
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
Voxel.
Smooth update from v 1.0.4.70HF. Running Windows 10 and Firefox from an Ethernet connected desktop.
I also managed to get the Kamoj add-on reinstalled.
Thank you for your work!
Excellent as always ! Currently running the snapshot version and no issues anywhere.
P.S - Voxel, are you planning to add more TCP congestion control algorithms in future ? Some modern ones like BBR, C2TCP or even PCC ?
Cheers
