GT-BE98 WIFI 7
John Fitzgerald
@RMerlin
We gonna get your special sauce for this???
@RMerlin
I wonder if it's going to have the same screwed up wireless lan interface lineup that the AXE16000 has... if so, RTRMON is set! :p
(BTW, you might want to remove that "release" tag on this thread, else certain forum members will start getting all upset.) ;)
Merlin support depends on the chipset the router uses. It could be Broadcom (BCM4398), but there is also Qualcomm (Pro 1620) and Mediatek (Filogic 380) that make a WiFi 7 router chipset. If it's Broadcom we might get lucky.
I did a little more digging and found this schematic drawing from Broadcom:
That looks very much like the configuration offered by this GT-BE98 minus the two BCM50991 2.5G LAN's.
I think the only thing it's missing is that RJ-11 port for my fax machine. :p
Would the BETA tag be better???
Fixed: I'll let the boss fix it if he thinks it's the wrong tag. It is a new release to market...
I think you'd need a "TBD" tag. ;)
And here is the none GT version:
ASUS RT-BE96U
With semiconductors shrinking, why do these things keep getting bigger???
Simple. More WiFi's = more antennas = more bandwidths = bigger internet tubes.
Your Google Nest is like the fax machine in routers anyway. No "performance" design whatsoever. Read here what a proper router is:
The arachnid look has been hideous from the start.
How about small, demure, easy on the eyes, unobtrusive, attractive, easily hidden, blendable, ...
This is not a centerpiece for the dinner table as far as the looks go.
Available:
Available:
Camo is unattractive: Camo is suppose to blend with the environment, I think the blue light in the middle negates its purpose.
