Moving DHCP to Pi-Hole
Scott Kaforey
I'm already using Pi-Hole in a docker image on my NAS for DNS and it's working beautifully thanks to some posts I've seen here.
Right now I have the following settings so that I can basically force all of my local devices to use Pi-Hole for DNS, even if they're configured with hard coded DNS values:
Lan -> DHCP Server:
DNS Server 1 set to 192.168.1.2 (my pi-hole instance)
Advertise router's IP in additoin to user-specified DNS: Yes
Lan -> DHCP Director:
Enable DNS Director
Global Redirection: User Defined 1
User defined DNS 1: 192.168.1.1 (my router IP)
Client List Entry: My Pi-Hole mac setup with "No Redirection"
Wan-> Internet Connection:
DNS Server 1: Quad 9 (9.9.9.9)
DNS Server 2: 192.168.1.2 (My Pi-Hole instance)
/jffs/configs/dnsmasq.conf.add
I added the following to the end of the file (which I use for static dhcp list)
strict-order
add-mac
add-subnet=32
local=/1.168.192.in-addr.arpa/
On my pi-hole, I have the following configured:
Settings -> DNS
My upstream servers are setup for Quad 9 and Cloudflare
Everything else is disabled except for I currently have conditional forwarding on setup with the values
192.168.1.0/24, 192.168.1.1, <blank local domain name>
So up to this point, everything is great. I am getting hostnames in my pi-hole logs and I can filter things on a per client basis if I want to.
I'm looking to move DHCP over entirely to the Pi-Hole and I was assuming I need to do the following:
1) Turn off the DHCP Server on the router under LAN->DHCP Server
2) Turn off conditional forwarding on the Pi-Hole.
3) Turn on the DHCP Server on the Pi-Hole
4) Import my static dhcp list from the router to the Pi-Hole (changing the formatting as required)
Do I need to change anything else that I may have missed?
Thank you in advance for your help!
Last time I checked AiMesh required DHCP on the main router. May not work if you have AiMesh setup.
