RBR50v2 - reset to stock or convert to satellite
CraigR
I picked up a cheap RBR50v2 which, I have subsequently learned, wasn't working properly - seems like previous user had a go at conversion and got stuck ?
Anyway I have dismantled it and have it connected it to my PC via a serial adapter and putty.
If possible I would like to convert it to a satellite, and failing that, set it back to stock router with latest firmware.
I have read through a few threads about the v2 bricking if done incorrectly, but as I have nothing to lose, thought I would have a go
So, for my satellite conversion attempt, I have changed the model id to RBS50 (from RBR50) and board data to 1102 (from 1101).
the router has a correct mac address
Do I need to do anything else before I try to flash the firmware ? and could someone please advise if i can use stock FW or do i (should I) use the voxel FW ?
Grateful for any advice. Thx
- I found the thread I needed.
Set model id and board data back to original settings and used tftpd to flash the firmware.
Looking good
Many thanks to all contributors ;-)
