Tutorial **Tailscale On Merlin**
So far so good, after my reinstall early this morning, so I am about 7 hours in on the corrected S06tailscaled and with 1.58.2-1. Tested using my phone on LTE only. So assuming it holds I am going to do the 1.58.2-1 to 1.64.0 update later this afternoon and see if that still holds.
Not sure why it bailed out yesterday, I was doing a few things with Firmware updates at the time, as well as starting with 1.64.0 and an incorrect S06tailscaled script, so maybe that was it.
Ok, ok, nice to hear… Please share your experience…
In relation to performance, do you see any relevant difference?
Not too much to share really, easy to install, yet to update it and test it.
Subjectively, nothing noticeable.
I’d have to run iPerf3 -s on the Router (it's built-in), enable ICMP Ping on the Firewall Tab of the Router, then connect to it using an iPerf App on my phone (Client Mode, Reverse Mode) to get a quantitative result for each. However I’m probably not going to run userspace mode then test it, then install kernel mode then test, just to find out sorry, maybe someone else can do that one day :).
See here for some mode differences and that userspace mode isn’t necessarily slow or slower, at least at the time of writing that second article.
I also read somewhere (2020 post) that WG on which Tailscale is based runs natively in Linux 5 and 6. Our routers run Linux 4. I do not really understand the concepts in that link much TBH; only that the kernel mode was faster.
So TLDR. I’m just going to take folks word for it :). Right now for me, stability and reliability governs over performance.
[EDIT] Please see the released Tailmon Script by Viktor Jaep
I updated tailscale.ipk and opkg install tailscale*.ipk (latest version) works by default.
If you fail to install tailscale.ipk then proceed with tailscale_nohf.ipk
Before installing anything you need to do clean install, means to uninstall all previous versions u had.
opkg remove tailscale
and
opkg remove tailscale_nohf
Now run update:
opkg update
Now install optional entware packages:
opkg install entware-opt
opkg status entware-opt #confirm they are installed
Install tailscale:
or
opkg install tailscale_nohf_*.ipk
Check your arch:
opkg print-architecture
Choose right architecture:
Github - files are on my github
After install u need to start Tailscaled:
/opt/etc/init.d/S06tailscaled start
Now check if Taiscaled is still running:
/opt/etc/init.d/S06tailscaled check
Then run simply tailscale up and click on the link to authorize.
(alternative: tailscale up --auth-key=<your-auth-key>)
I forgot to update permissions, so execute these after installation:
chmod 755 /opt/bin/tailscale
chmod 755 /opt/bin/tailscaled
Use this command to add your routes:
tailscale up --accept-routes --advertise-routes=192.168.0.0/24,192.168.1.0/24 #(make sure to use your subnet)
(you need to approve them in tailscale dashboard)
For default commands just type "tailscale" to list, or execute(example):
tailscale version
In order to use "tailscaled" start/stop/check use this command:
In case u want to run AdguardHome/PiHole alongside tailscale:
tailscale up --accept-dns=false
I made a streamlined guide which works hopefully on every Merlin. I had trouble installing on my RT-N18U but in the end I made it.
#You can use my script or install manually. Script is simple and robust, worked for me.. Github
wget https://raw.githubusercontent.com/bobanilic/MerlinScale/main/install_tailscale.sh && chmod +x install_tailscale.sh && ./install_tailscale.sh
Install Entware(from AMTM) and other necessary packages:
opkg install ca-bundle
opkg install tailscale #(tailscale_nohf -use this if you can't install main)
Go to website and download correct architecture (e.g., ARM, ARM64, x86_64).
Extract it and copy the content to update manually:
cp /tmp/mnt/USB/FOLDER/tailscale_1.64.0_arm/tailscale /opt/bin/
cp /tmp/mnt/USB/FOLDER/tailscale_1.64.0_arm/tailscaled /opt/bin/
edit /opt/etc/init.d/S06tailscaled and update ur ARGS:
ARGS="-tun=userspace-networking -statedir /opt/var/tailscale/"
You can run "tailscale update" to check for latest version and also to make sure that you downloaded the correct architecture
(if the architecture was wrong you will get an error)
If everything is OK, execute command "tailscale up" which will generate a link:
(you need to approve them in tailscale dashboard)​
tailscale start
Credits to Fakemanhk Reddit
Credits to RandomUser777
What version i need to download for my llinksys ea6900?
aarch64-k3.10
armv5sf-k3.2
armv7sf-k2.6
armv7sf-k3.2
mipselsf-k3.4
mipssf-k3.4
