ASUS XT8 dropout - momentarily disconnection
Armin6150
Hi All, hoping for some advice…
I’ve been using XT8 for 3 years now without any issues. I’ve been with the same provider for over a year now and no issues either. Past couple of weeks suddenly experiencing weird drop outs for a few seconds only and it then it fixes itself. It’s very annoying as I can’t figure out whether this is caused by my router or the provider.
Below is a snap shot log from my router, these logs are repeating itself every few minutes throughout the day.. can anyone make any sense of the logs? Some of the codes seems to be repeating every few minutes.. is that normal?
Apr 22 20:05:45 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 6A:6B:24:71:9D:D2, status: 0, reason: Previous authentication no longer valid (2), rssi:-74
Apr 22 20:05:45 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 6A:6B:24:71:9D:D2, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:-74
Apr 22 20:05:46 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 6A:6B:24:71:9D:D2, status: 0, reason: Disassociated due to inactivity (4), rssi:-74
Apr 22 20:05:49 wlceventd: wlceventd_proc_event(662): eth5: Disassoc 6A:6B:24:71:9D:D2, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Apr 22 20:06:53 roamast: [EXAP]Deauth old sta in 1 0: 32:04:B0:C8:0A:E2
Apr 22 20:06:53 roamast: eth5: disconnect weak signal strength station [32:04:b0:c8:0a:e2]
Apr 22 20:06:53 roamast: eth5: remove client [32:04:b0:c8:0a:e2] from monitor list
Apr 22 20:06:57 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 32:04:B0:C8:0A:E2, status: 0, reason: Previous authentication no longer valid (2), rssi:-84
Apr 22 20:06:57 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 32:04:B0:C8:0A:E2, status: 0, reason: Disassociated due to inactivity (4), rssi:-84
Apr 22 20:06:58 wlceventd: wlceventd_proc_event(662): eth5: Disassoc 32:04:B0:C8:0A:E2, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Apr 22 20:10:46 wlceventd: wlceventd_proc_event(685): eth5: Auth 6A:6B:24:71:9D:D2, status: Successful (0), rssi:0
Apr 22 20:10:46 wlceventd: wlceventd_proc_event(695): eth5: ReAssoc 6A:6B:24:71:9D:D2, status: Successful (0), rssi:-60
Apr 22 20:11:56 roamast: [EXAP]Deauth old sta in 1 0: 6A:6B:24:71:9D:D2
Apr 22 20:11:56 roamast: eth5: disconnect weak signal strength station [6a:6b:24:71:9d:d2]
Apr 22 20:11:56 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 6A:6B:24:71:9D:D2, status: 0, reason: Previous authentication no longer valid (2), rssi:-66
Apr 22 20:11:56 roamast: eth5: remove client [6a:6b:24:71:9d:d2] from monitor list
Apr 22 20:11:56 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 6A:6B:24:71:9D:D2, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:-66
Apr 22 20:11:57 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 6A:6B:24:71:9D:D2, status: 0, reason: Disassociated due to inactivity (4), rssi:-66
Apr 22 20:11:59 wlceventd: wlceventd_proc_event(662): eth5: Disassoc 6A:6B:24:71:9D:D2, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Apr 22 20:12:58 wlceventd: wlceventd_proc_event(685): eth5: Auth 6A:6B:24:71:9D:D2, status: Successful (0), rssi:0
Apr 22 20:12:59 wlceventd: wlceventd_proc_event(695): eth5: ReAssoc 6A:6B:24:71:9D:D2, status: Successful (0), rssi:-67
Apr 22 20:14:42 bsd: bsd: Sending act Frame to 6a:6b:24:71:9d:d2 with transition target eth4 ssid fc:34:97:ad:a1:20
Apr 22 20:14:43 bsd: bsd: STA:6a:6b:24:71:9d:d2 no response
Apr 22 20:14:43 bsd: bsd: Sending act Frame to 6a:6b:24:71:9d:d2 with transition target eth4 ssid fc:34:97:ad:a1:20
Apr 22 20:14:44 bsd: bsd: STA:6a:6b:24:71:9d:d2 no response
Apr 22 20:14:51 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 6A:6B:24:71:9D:D2, status: 0, reason: Previous authentication no longer valid (2), rssi:-83
Apr 22 20:14:51 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 6A:6B:24:71:9D:D2, status: 0, reason: Disassociated due to inactivity (4), rssi:-83
Apr 22 20:14:52 wlceventd: wlceventd_proc_event(662): eth5: Disassoc 6A:6B:24:71:9D:D2, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Apr 22 20:18:02 wlceventd: wlceventd_proc_event(685): eth5: Auth 6A:6B:24:71:9D:D2, status: Successful (0), rssi:0
Apr 22 20:18:02 wlceventd: wlceventd_proc_event(695): eth5: ReAssoc 6A:6B:24:71:9D:D2, status: Successful (0), rssi:-59
Apr 22 20:18:30 roamast: [EXAP]Deauth old sta in 1 0: 6A:6B:24:71:9D:D2
Apr 22 20:18:30 roamast: eth5: disconnect weak signal strength station [6a:6b:24:71:9d:d2]
Apr 22 20:18:30 roamast: eth5: remove client [6a:6b:24:71:9d:d2] from monitor list
Apr 22 20:18:30 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 6A:6B:24:71:9D:D2, status: 0, reason: Previous authentication no longer valid (2), rssi:-76
Apr 22 20:18:30 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 6A:6B:24:71:9D:D2, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:-76
Apr 22 20:18:31 wlceventd: wlceventd_proc_event(645): eth5: Deauth_ind 6A:6B:24:71:9D:D2, status: 0, reason: Disassociated due to inactivity (4), rssi:-76
Apr 22 20:18:33 wlceventd: wlceventd_proc_event(662): eth5: Disassoc 6A:6B:24:71:9D:D2, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Apr 22 20:47:54 wlceventd: wlceventd_proc_event(685): eth5: Auth 32:04:B0:C8:0A:E2, status: Successful (0), rssi:-75
Apr 22 20:47:54 wlceventd: wlceventd_proc_event(695): eth5: ReAssoc 32:04:B0:C8:0A:E2, status: Successful (0), rssi:-75
Apr 22 20:48:07 wlceventd: wlceventd_proc_event(685): eth5: Auth 62:CD:16:38:F4:83, status: Successful (0), rssi:0
Apr 22 20:48:07 wlceventd: wlceventd_proc_event(695): eth5: ReAssoc 62:CD:16:38:F4:83, status: Successful (0), rssi:-48
Any idea if the logs are showing any issues? I should have added I’m with YouFibre 1Gig package and never had any issues even during these dropouts I get speed of 800/900meg
