o-l-a-v
Bricked RT-N66U? (I've searched google&snb already)
Hi guys!
I had my RT-N66U sat up with tomato and everything. Then i wanted to flash the newest asus firmware, because of support of using it as repeater.
So i started the router directly to restoration mode, fired up the asus restoration tool, and started to upload latest firmware.
I did not upload the zip, i unpacked using 7-zip. I also ran the tool as admin. Turned of all wireless connections. No other connections to the router other than my PC through LAN 1. Not WAN.
After it's supposed to be finished doing the restoration, the tool says "can't connect to the router". F*ck..
So I try to set the router to restoration mode again. Same thing happen. I get to upload the firmware, but after the tool is finished with restoring progress, it says it cannot connect to the router.
I try to set a static ipadress
gateway: 192.168.1.1
ip: 192.168.1.2
subnet mask: 255.255.255.0
No difference.
When i try to access "192.168.1.1" through my web browser. "No connection available".
I try to ping it. Success
I try to access it through telnet (putty): Connection refused.
When i power on the router normally, only power lamp constantly on. No ipadress is given to my computer.
When i power on the router holding wps, after releasing it after 30sec, power and 2.4ghz lamp is on. But i can't see any wireless connections.
When i enter restoration mode, same things happen. Tool finds it, uploads successfully, the percentage bar telling me status of restoration progress gets to 99%, then "failed, can't connect to router".
What to do guys?
I checked before i flashed tomato that i had latest CFE version. (using asuswrt-merlin).
Hi guys!
ip: 192.168.1.2
No difference.
What to do guys?
