Creating an ethernet guest network
discopatrick
I have created a WiFi guest network on my RT-AX86U Pro using the YazFi plugin, and I'm happy with the results.
How could I create a similar guest network, but over ethernet?
Is there another plugin that does this? Or perhaps someone has an example of a custom config file?
The following add-on script may address what you are seeking (or it may not).
Thanks for the suggestion @bennor . Unfortunately the author says it's not compatible with other network isolation scripts like YazFi, so I'm hesitant to try it out.
It should be as simple as creating a VLAN and adjusting the firewall rules for access since you are 1 device.
Or, if you have a spare router, just set it up behind your main router as a wired guest network.
