I have been using T-Mobile's CellSpot router that I hacked and flashed back to stock AC68U. I love the AsusWRT firmware because it allows me to set the router as the NETBIOS Master Browser. So, I am stuck on Asus unless there is a different router that can be setup that way.
I dropped T-Mobile's service and they want their router back so I may have to get a new one. T-Mobile will charge me $99 if I don't return it which is actually a pretty good deal for an Asus RT-AC68U but I hate, hate, hate the upright form factor. I want one that lays flat or I can mount on the wall.
Anyway, here is the nitty gritty details. All I need out of the router is good routing ability and solid wireless N performance. I have a TP-Link Archer C7 that I can set as an AP if I need wireless AC but it's v1 of that router and it has issues with my Ooma Teleo and my Blackberry Z10. The RT-AC68U has had no problem with any devices.
Bottom line, how do these 3 routers compare for normal network routing and wireless N performance? I am not ready to drop the $$$ for any of the newer ones and I just don't need that much wireless bandwidth at this point. Is there any point to consider a Refurbished or Open Box AC87R/U? My gut says that the N66U is plenty for what I need but if general routing is greatly improved with either of the other two then I can pony up.
A cursory glance through reviews and rating would leave me to believe that routing throughput would be roughly equal between the AC68U and the AC87U with the N66U lagging a little behind. I doubt it would be noticeable with the N66U but I am the kind of guy that likes to "spring for the bigger engine".
Opinions?
Opinions?
