Thank you, It was on, I shut it off and still same problem, I have to hit the WAN apply to get WAN access, but it sounded like it would work. thanks.Do you also have a setting at USB Application > 3G/4G?
I have this on the RT-N66U and have Enable USB Modem set to no.
Anyone have any Ideas on why I get no WAN until I hit apply after a reboot with merlins firmware?
As far as PS4 lag free settings see this post.
http://www.snbforums.com/threads/dd-wrt-for-rt-ac87r.22421/page-12#post-173031
I don't have the time to dig through your logs because I'm already backlogged with other issues. However there's a chance that one of those issues I've finally tracked down could be related to your boot time issue. Can you give this test build a try?
http://www.mediafire.com/download/rso26r5zb8g9sh8/RT-AC87U_3.0.0.4_378.52_alpha3.zip
Make sure not to confuse that build with the one posted by someone else - this is based on newer development code. The build date on the Sysinfo page should report it was built today, from user merlin@somevalue.
Your testing does not seem to be very systematic. You are creating as many possible bugs as there are in the firmware, I suspect, by jumping back and forth on different firmware forks.
I agree completely with L&LD. If it were me, I would stay with the 1-20-2015 version of DD-WRT which you claim is the most stable of all the firmwares out there and give your router a break for an extended period. Your poor router, after all these hard resets and flashings, it must have had some of its service life used up in a relatively short period of time. NVRAM has a limit on how many times it can be overwritten & formatted IIRC. However, I have no idea what those limitations might be.
Cool!!!!!!THANK YOU it works!!!!
Cool
The short version:
The long version:.
YesAny chance I can go straight to this from .51 Beta without resetting everything?
i can say only one word. GREAT !!!!I don't have the time to dig through your logs because I'm already backlogged with other issues. However there's a chance that one of those issues I've finally tracked down could be related to your boot time issue. Can you give this test build a try?
What's the ps4's DMZ setting for if UPnP is enabled?DMZ to ps4
WAN Page
- OpenDNS Family DNS servers (208.67.222.123 & 208.67.220.123)
- set DHCP Query Frequency to Normal (I need this, some do not)
- UPNP Allowed internal & external port range set from 1 to 65535.
Thread starter | Title | Forum | Replies | Date |
Wireguard benchmark test on RT-BE96U | Asuswrt-Merlin | 41 | |
Z | Speed Test Discrepancy | Asuswrt-Merlin | 5 | |
Beta Asuswrt-Merlin 3004.388.6_x test builds (dnsmasq 2.90) | Asuswrt-Merlin | 102 | |
B | Solved Speed test | Asuswrt-Merlin | 11 |
Welcome To SNBForums
