Hi.
I have problem with my Lumia 925 and 5GHz band. My phone can't connect when SSID is hide. When SSID is not hide then no problem.
I manually add SSID and wifi key but phone can't connect.
You're kidding, right ? Using 5GHz is problematic, so we should use 2.4GHz, or cable ?Hiding SSID's is no security, one must recognize this, and it leads to problems like this...
this is workaround not fixNo, simply unhide the ssid.
In this case, the fix and the workaround are one and the same.
Because hidden ssid's were obsolete a decade ago from any security or other aspect.
ok, in this case Asus should remove this feature right ?
Dear L&LD i know that this feature (ssid hide) it has nothing to do with security, but this feature exist and i want use it.
Welcome To SNBForums
