RT-AC87U Quantenna soc temperatures
leoo2001
How its possible to had a 3o degrees difference between rfic and bbic if they are running on the same chipset.
admin@RT-AC87U-5348:/tmp/home/root# cat /proc/dmu/temperature
CPU temperature : 77�C
admin@RT-AC87U-5348:/tmp/home/root# qcsapi_sockrpc get_temperature
temperature_rfic_external = 0.0
temperature_rfic_internal = 51.5
temperature_bbic_internal = 80.0
Look like I have to open the router and change the inside and outside thermal pads with mx-4. On AC56U doing this i have lowered the cpu temp from around 90 to 65 degrees Celsius.
First of all: Where is the problem? There is no problem as the chips are ceriffied to operate >120° C... :rolleyes:
For you further evaluation: my temps are shown below!
chief@RT-AC87U:/tmp/home/root# cat /proc/dmu/temperature
CPU temperature : 85▒C
chief@RT-AC87U:/tmp/home/root# qcsapi_sockrpc get_temperature
temperature_rfic_internal = 64.4
temperature_bbic_internal = 75.0
my temp.
VANT@RT-AC87U:/tmp/home/root# cat /proc/dmu/temperature
CPU temperature : 72▒C
for now 5GHz radio is off
VANT@RT-AC87U:/tmp/home/root# qcsapi_sockrpc get_temperature
temperature_rfic_internal = 62.8
temperature_bbic_internal = 65.0
Broadcom chips are certified to 120°, but quantenna are operational till 90° if I'm not mistaken. Anyway, I already changed the paste but without much success. At least for quantenna soc it varies between 70-75° and 5ghz now is worst upto 56°. Maybe later I will remove the metal plates (caps) and install the heatsinks directly on the chips.
ASUSWRT-Merlin RT-AC87U_3.0.0.4 Sun Mar 20 19:53:07 UTC 2016
CPU temperature : 73�C
temperature_rfic_internal = 52.9
temperature_bbic_internal = 70.0
