pardon the ignorance,
I would like to set up an AiMesh Node with static IP in order to share an USB printer over the network. Currently, the node is in DHCP mode; while the IP address has not (or does not) change, I like to assign an IP address to it so that my internal network is a bit more organized.
I can't seem to find a way to setup the AiMesh Node with a static IP address; when pairing the node with router the IP address is assigned via DHCP. After which, we basically lose direct access to the node.
any help is very much appreciated,
