TP Link touch p5 throughput data
(awaiting chipset details and specs )
throughput tests are recorded by networx's speed meter and are the average transfer rates over the life of the transfer
the file is a single Mpeg4 file 1.85 GB transferred to and from via the windows file transfer method ( eg samba )
test layout and location info can be found in the link below
https://onedrive.live.com/?cid=7D5C...1a0742!812&parId=7d5cb240be1a0742!144&o=OneUp
test hardware nas connected directly to the router is a dlink dns-327L
test comp has a solid state drive and is using the asus pce-ac68 for the wifi connection
ethernet to ethernet ( eg comp and nas connected by ethernet to router )
read 108MB/s write 64.5 MB/s sync 1 gig
USB throughput
ethernet to use 3
read 44.8 MB/s write 19.6 MB/s
Wifi throughput
note: at this stage was unable to set the 2.4 gig to 40mhz without obss coexistence so 2.4 gig reading are at 20mhz single stream
5 gig at 3 feet away same room location A
read 48.0 MB/s write 31.2 MB/s sync 877.5M
2.4 gig at 3 feet away same room location A
read 16.2 MB/s write 14.1 MB/s sync 260M
5 gig at 10 meters away location C
read 50.1 MB/s write 35.2 MB/s sync 877.5M
2.4 gig at 10 meters away location C
read 11.9 MB/s write 11.4 MB/s sync 195M
5 gig at 25 meters away location E
read 15.6 MB/s write 7.9 MB/s sync 87.5M
2.4 gig at 25 meters away location E
read 11.1 MB/s write 9.25 MB/s sync 156M
there you go its pretty reasonable when compared to other 1900ac class routers i have tested
inSSIDer rssi data can be found in the link below for the locations used
https://onedrive.live.com/?id=7d5cb240be1a0742!964&cid=7D5CB240BE1A0742
