TUF AX6000 When Adaptive QOS is enabled, Wireless upload speeds are reduced by less than half.
MT7988A
hello.
Use TUF AX6400 (Chinese version TX AX6000).
When QOS is enabled, Wireless upload speeds are reduced by less than half.
Is this a defect?
QOS ON(=NAT OFF)
WIRELESS
QOS ON(=NAT OFF)
WIRE
QOS OFF
WIRELESS
QOS OFF
WIRE
When you turn on QOS, only the WIFI UPLOAD speed will be reduced by half.
Only CPU Core4 is at 100%.
Multi-thread processing is not possible.
Just turn off QoS. there's no need for QoS with that kind of speed internet connection.
Also, as QoS makes sure to prioritise data for whatever you set it up to, the router might think that some device that should be prioritised ned data and thus the speed for your other devices is dropped, as intended.
Even if QOS is turned on, there is almost no speed reduction.
Only wifi upload speed decreases.
CPU core load seems strange.
Multi-threading does not work.
Yes, QoS and NAT aren't a multithreaded process (on these devices).
