Upgraded Ac86u to 386.13_2 and cannot find wireguard
ASadani
Hi all, I've upgraded to the latest merlin 386.13_2 on the AC86u and cannot find the wireguard on the VPN server. I have been using the 386 firmware for a long time due to the VPN applet from the provider which still works perfectly fine. Am I missing something? Appreciate your help
WIreguard is not supported on 386, it's only available on models running the 388 firmware.
I appreciate the update. I just learned today that the ac86u is EOL. At some point, I'll upgrade to the AX86u pro as it has a 2.0 GHz processor which will work slightly better than the 1.8 that exists in the AC86u today. The router is rock solid with the 86u acting as a primary and a mesh
