Upgraded my ASUS, issues with NordVPN via OpenVPN
asusface
Hello. First post
I've owned an ASUS TUF-AX5400 for some time, and have successfully run Nord VPN via OpenVPN, following the guide on the Nord site
A couple of weeks ago I finally applied the Merlin FW to the router - 3004.388.5_0-gnuton1_tuf specifically
I got it from here: https://github.com/gnuton/asuswrt-merlin.ng/releases/tag/3004.388.5_0-gnuton1 (thanks @GNUton )
Now... despite following the steps provided on the Nord site, I cannot get an active VPN running - https://support.nordvpn.com/hc/en-us/articles/20319214011921-AsusWRT-Merlin-setup-with-NordVPN
I was particularly confused by Nord's suggestion to use their DNS servers - is this really necessary?
The screen on the router management page has changed, the previously available 'VPN Fusion' has gone. Fine, but I can't see clearly if I'm applied the right settings
The other issue is that I can't seem to use the ASUS iphone app to turn the VPN on and off as I please - this was super useful
Completely understand that Merlin offers so much, and really dont want to have to downgrade my router... so any advice appreciated
thanks
Hello. First post
thanks
Why don't you post some screen shots of your VPN client and any custom config entries you are using? We don't have much to go on here... Also, Nord's guides are horrendous, so I had put together some how-to's here, so please see if this helps?
Hey - thanks for sharing that link. I will run thru your steps and see if that helps
Can I take it that the Nord advice to change DNS is nonsense?
Also, will I still be able to use the Asus Router app for easy switching on/off? It doesnt seem to have a switch for clients, just Fusion?
Change "Username / Password Auth. Only" to No.
Obviously "Redirect Internet traffic through tunnel" has to be set to something other than No.
Merlin's firmware does not support Asus' phone app. His VPN implementation in particular is completely different.
Yes, the Nord advice to change WAN DNS is nonsense. Use the VPN client's DNS setting (e.g. Disabled or Exclusive).
Thats brilliant colin - thanks
My setup didnt work initially but I made your changes and now the vpn is active
Cheers
