Why my AX11000 router shows 2x 2.4MHz bands and 1 5GHz bands
Sunny786
Why my AX11000 router shows 2x 2.4MHz bands and 1 5GHz bands Instead of 2 5GHz bands
because one of your bands is really 5g 1 but is improperly named you can fix this by adjusting in inside your settings you must have smart connect enabled which is using the name from your 2.4Ghz band over to your 5ghz band.
Yes, you are right. I had to change the SSID name to 5GHz-1 & 5GHz-2 separately.
