Just about at my wit's end trying to figure this out: I Have a pair of XT9's connected via wired backhaul AiMesh at opposite ends of the house (1 downstairs + 1 up 2 flights of stairs.) and am utilising the 5GHz-2 band to connect my wireless device (macbook pro) as that is what is giving me the most stable/fastest speeds.
The problem is the macbook doesn't seem to want to roam between the currently connected node and main router and visa-versa. I must always manually reconnect in order to get it to switch. I have read up about Macs being rather sticky and OSX not searching for a new access point until the current connection hits an RSSI threshold of -75dBm. Well I am sitting here with between -80 and -83 dBm connected to the main router downstairs and it still will not switch to the node upstairs which is right next to me with -30ish RSSI. The main router and node could not be further apart as they are.
Roaming seems to work pretty well from what I can tell when utilising the 2.4GHz and 5GHz-1 bands at the cost of decreased stability/speed performance. Not ideal.
On the 5GHz-2 band I have:
Adjusted roaming assistant to varying values from -40 to -70
Disabled Roaming assistant completely
Diasabled Universal beamforming
Adjusted tx power levels all the way through from Performance down to power saving
Tested a variety of different bandwith and control channel settings.
I simply cannot seem to get it to roam correctly. Any help or advice?
