1.1.1.1 getting blocked by avahi?
That special 1.1.1.1 interface only comes up temporarily during boot time.
Is there a way I can disable this? It doesn't go away and seems to route it still, can't use 1.1.1.1 for anything.
Here's dig and nslookup.
nahventure@ROUTER:/tmp/home/root# dig google.com @1.1.1.1
; <<>> DiG 9.12.3-P4 <<>> google.com @1.1.1.1
;; global options: +cmd
;; connection timed out; no servers could be reached
C:\Users\nahventure>nslookup google.com 1.1.1.1
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
Address: 1.1.1.1
*** Request to UnKnown timed-out
What do you get on your router from these commands?
ifconfig -a
netstat -rn
nahventure@ROUTER:/tmp/home/root# ifconfig -a
aux0 Link encap:Ethernet HWaddr AC:9E:17:48:EF:E8
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:291173 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:23324659 (22.2 MiB) TX bytes:0 (0.0 B)
Interrupt:180 Base address:0x5000
br0 Link encap:Ethernet HWaddr AC:9E:17:48:EF:E8
inet addr:172.16.1.1 Bcast:172.16.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING ALLMULTI MULTICAST MTU:1500 Metric:1
RX packets:1617562 errors:0 dropped:0 overruns:0 frame:0
TX packets:1416184 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:183464176 (174.9 MiB) TX bytes:443753637 (423.1 MiB)
br0:0 Link encap:Ethernet HWaddr AC:9E:17:48:EF:E8
inet addr:169.254.39.251 Bcast:169.254.39.255 Mask:255.255.255.0
eth0 Link encap:Ethernet HWaddr AC:9E:17:48:EF:E8
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:25010381 errors:0 dropped:0 overruns:0 frame:0
TX packets:13949333 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4031990672 (3.7 GiB) TX bytes:843864043 (804.7 MiB)
Interrupt:181 Base address:0x6000
eth1 Link encap:Ethernet HWaddr AC:9E:17:48:EF:E8
RX packets:9136509 errors:0 dropped:0 overruns:0 frame:4790606
TX packets:16878570 errors:2 dropped:0 overruns:0 carrier:0
RX bytes:2475469139 (2.3 GiB) TX bytes:3191504574 (2.9 GiB)
Interrupt:163
ifb0 Link encap:Ethernet HWaddr F2:25:59:E6:DD:08
BROADCAST NOARP MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
collisions:0 txqueuelen:32
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
ifb1 Link encap:Ethernet HWaddr 26:74:89:5D:24:20
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MULTICAST MTU:16436 Metric:1
RX packets:481305 errors:0 dropped:0 overruns:0 frame:0
TX packets:481305 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:113449889 (108.1 MiB) TX bytes:113449889 (108.1 MiB)
lo:0 Link encap:Local Loopback
inet addr:127.0.1.1 Mask:255.0.0.0
tun21 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 -00
inet addr:10.8.0.1 P-t-P:10.8.0.1 Mask:255.255.255.0
UP POINTOPOINT RUNNING NOARP PROMISC MULTICAST MTU:1500 Metric:1
vlan1 Link encap:Ethernet HWaddr AC:9E:17:48:EF:E8
RX packets:1308591 errors:0 dropped:0 overruns:0 frame:0
TX packets:2237177 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:171540695 (163.5 MiB) TX bytes:1449886886 (1.3 GiB)
vlan2 Link encap:Ethernet HWaddr AC:9E:17:48:EF:E8
inet addr:192.168.1.36 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1492 Metric:1
RX packets:23992963 errors:0 dropped:0 overruns:0 frame:0
TX packets:11891610 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:29517273762 (27.4 GiB) TX bytes:3582803698 (3.3 GiB)
wl0.1 Link encap:Ethernet HWaddr AC:9E:17:48:EF:E9
RX packets:2284739 errors:0 dropped:0 overruns:0 frame:4790606
TX packets:6599007 errors:1 dropped:0 overruns:0 carrier:0
RX bytes:1042463361 (994.1 MiB) TX bytes:3682780667 (3.4 GiB)
netstat -rn
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
192.168.1.1 0.0.0.0 255.255.255.255 UH 0 0 0 vlan2
169.254.39.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
10.8.0.0 0.0.0.0 255.255.255.0 U 0 0 0 tun21
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 vlan2
172.16.1.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 vlan2
pastebin since it turned out ugly in spoiler, https://pastebin.com/vEWaieym
Well I can't see any trace of 1.1.1.1 or a subnet that would contain it.
What happens if you try a "ping 1.1.1.1" from the router?
EDIT: Are you using DNS Filter? What is the output of "iptables-save"?
Server: UnKnown
Address: 1.1.1.1
No, it's not a feature, it's how the architecture was designed for that router model.
That interface should only be there during boot time, so it won't interfere with normal usage once it's fully initialized.
It works on my 87U:
grifo@r1:/tmp/home/root# nslookup google.com 1.1.1.1
Server:    1.1.1.1
Address 1: 1.1.1.1 one.one.one.one
Address 1: 2a00:1450:4002:801::200e mil04s03-in-x0e.1e100.net
Address 2: 216.58.205.110 mil04s26-in-f14.1e100.net
My logs also show avahi-daemon registering 1.1.1.1 on the LAN interface but then it gets withdrawn.
Sep  5 18:04:08 r1 avahi-daemon[1987]: avahi-daemon 0.7 starting up.
Sep  5 18:04:08 r1 avahi-daemon[1987]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Sep  5 18:04:08 r1 avahi-daemon[1987]: No service file found in /tmp/avahi/services.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Loading new alias name RT-AC87U.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Joining mDNS multicast group on interface br2.IPv4 with address 192.168.202.254.
Sep  5 18:04:08 r1 avahi-daemon[1987]: New relevant interface br2.IPv4 for mDNS.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Joining mDNS multicast group on interface br1.IPv4 with address 192.168.201.254.
Sep  5 18:04:08 r1 avahi-daemon[1987]: New relevant interface br1.IPv4 for mDNS.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Joining mDNS multicast group on interface br0.IPv4 with address 1.1.1.1.
Sep  5 18:04:08 r1 avahi-daemon[1987]: New relevant interface br0.IPv4 for mDNS.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.1.1.
Sep  5 18:04:08 r1 avahi-daemon[1987]: New relevant interface lo.IPv4 for mDNS.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Network interface enumeration completed.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Registering new address record for 192.168.202.254 on br2.IPv4.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Registering new address record for 192.168.201.254 on br1.IPv4.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Registering new address record for 1.1.1.1 on br0.IPv4.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Registering new address record for 169.254.39.93 on br0.IPv4.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Registering new address record for 192.168.1.254 on br0.IPv4.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Registering new address record for 127.0.1.1 on lo.IPv4.
Sep  5 18:04:08 r1 avahi-daemon[1987]: Registering new address record for 127.0.0.1 on lo.IPv4.
Sep  5 18:04:09 r1 avahi-daemon[1987]: Server startup complete. Host name is RT-AC87U-6BD0.local. Local service cookie is 1739969676.
Sep  5 18:04:09 r1 avahi-daemon[1987]: Alias name "RT-AC87U" successfully established.
Sep  5 18:04:09 r1 kernel: br1: port 2(wl0.1) entering forwarding state
Sep  5 18:04:09 r1 kernel: br1: port 1(vlan201) entering forwarding state
Sep  5 18:04:09 r1 kernel: br2: port 1(vlan202) entering forwarding state
Sep  5 18:04:09 r1 kernel: ip_set: protocol 6
Sep  5 18:04:24 r1 avahi-daemon[1987]: Withdrawing address record for 1.1.1.1 on br0.
Sep  5 18:04:24 r1 avahi-daemon[1987]: Leaving mDNS multicast group on interface br0.IPv4 with address 1.1.1.1.
Sep  5 18:04:24 r1 avahi-daemon[1987]: Joining mDNS multicast group on interface br0.IPv4 with address 169.254.39.93.
