I'm looking into upgrading from my AC68U, and have an Intel 9260 with 160mhz support. I'd be satisfied with gigabit speed, since that's what my ISP caps it at, anyway. Instead of buying an expensive Wifi 6 model, I'm looking to save some money on a lower priced unit, or maybe even a used one. The prices on the AC88U tend to run a little higher. The AC86U and AC3100 should perform about the same, and could save me even more money.
I was wondering if someone could help me find out whether the 160mhz option which exists for recent manufactured AC88U with BCM4366E also exists for AC3100 and AC86U which also support the "RANGE BOOST" feature? I know that the AC3100 used to have the same processor as the AC88U (BCM4366). However,I understand there are some newer AC88U units which have the updated BCM4366E, which introduced "RANGE BOOST", as part of its "Wave 2" features. I see where the newer AC86U and AC3100 have the "RANGE BOOST" feature, as well. Does this mean that they have the newer processors which introduce the Wave 2 feature, and 160mhz?
Can any owners confirm whether the 160 mhz option is showing in the settings, please?
Many thanks!
Many thanks!
