2.4Ghz WiFi on a RT-AC86U - what are the optimal settings?
Not to get off track but on Asus routers (under 5GHz pro settings), there’s MU-MIMO and then another MU-MIMO that’s combined with the OFDMA option. Is the first MU-MIMO for AC and the second one for AX? Just to clarify, I have both options disabled and I plan to keep it that way. I’m just curious why there are two different settings.
Thanks to all for your input!
I have taken the sum total of what all of you said - and it looks like we are kind of coalescing around this as a consensus.
Note: for ESP devices running Tasmota, it is recommended that the band is manually configured and NOT set to auto - due to devices not automatically recalibrating themselves (https://tasmota.github.io/docs/FAQ/#device-disconnects-from-wi-fi-often)
Enable Smart ConnectOFF
Band2.4 GHz
Hide SSIDNo
Wireless ModeN only
Channel bandwidth20Mhz
Control ChannelAuto initially, and then manually confirm/set for ESP devices
Authentication MethodWPA2-Personal
WPA EncryptionAES
WPA Pre-Shared KeyStrong
Protected Management FramesDisable
Group Key Rotation Interval3600
Enable RadioYes
Enable wireless schedulerNo
Set AP IsolatedNo
Roaming assistantDisable
Bluetooth CoexistenceDisable
Enable IGMP SnoopingDisable
Multicast Rate(Mbps)OFDM 6
Preamble TypeShort (but Long could be better for IOT devices)
AMPDU RTSEnable
RTS Threshold2347
DTIM Interval1 (but there is disagreement)
Beacon Interval100
Enable TX BurstingDisable
Enable WMMEnable
Enable WMM No-AcknowledgementDisable
Enable WMM APSDEnable (there is disagreement)
Optimize AMPDU aggregationDisable
Modulation SchemeUp to MCS 7 (802.11n)
Airtime FairnessDisable
Multi-User MIMODisable
Explicit BeamformingDisable
Universal BeamformingDisable
Tx power adjustmentPerformance
Those look good. Keep an eye on things for a few weeks. I had to disable WMM APSD because it caused some disconnection issues with a couple of devices, and it took a while for them to reconnect after waking up. You might not have this issue at all, but just keep an eye out for it.
Also, since you have your wireless mode set to “N only”, I’m not sure there’s any value in changing the multicast rate from the default “auto” but @sfx2000 can confirm.
@Xboxsx4life good point. Again, I was just creating the table above, based on a perceived consensus in this forum - in which @sfx2000 said "APSD isn't a bad thing, short preambles are good, and multicast rates at 6Mbps which basically forces the basic rates to 6 and above with OFDM".
HOWEVER, I am more drawn to your viewpoint "I have that band set to N-only with short preamble. Those settings combined with DTIM 1 and beacon interval at 100ms have given me fast and problem-free connectivity across all my IoT devices" - but only because, I am running approx 20 various ESP Sonoff devices running Tasmota, and am amazed that these things work at all - so want to given them all the support possible.
As mentioned earlier there is no best settings. It's all theory and the reality is access point, clients and environment specific. You have to be happy your RT-AC86U is still working properly. This router model has much more serious issues than the effects of APSD enabled/disabled. It is also approacing EoL.
Asus could have done better here, IMHO...
Mostly because MU-MIMO (uplink and downlink) and OFDMA are really two separate functions...
I agree...
IMHO - there's a lot of settings that are exposed that if one changes them, it can hurt more than help...
Everyone likes to have knobs and levers to tweak - but generally the defaults are pretty good as they are - pick a channel and that's about it...
Indeed. In Asuswrt way too many settings are exposed for no good reason, some do nothing and some are actually confusing because there is no dependencies and you can have Legacy B/G in General with Beamforming, MU-MIMO, TurboQAM and whatnot enabled in Professional.
I'm currently testing the following 2.4GHz settings on my network, OP:
OFF, disabled.
So far, no issues.
You mean, that you turned off 2.4Ghz completely?
yes, correct. 5GHz wireless only.
From a hardware manufacturer that markets its products as AiMesh compatible, or AiMesh as being a main feature, it makes sense: you want lots of fast APs wherever you need signal, so who cares about the extra range of a 2.4GHz band radio?
So off it went as a test, and so far, so good on my network: I've a 5GHz 802.11n link to my Media Bridged RT-n66u, and everything else wifi is 5GHz AC+ capable or wired.
The Media Bridge link speed is 450Mbps both ways, I've tweaked my AC86's 5GHz to be 40MHz wide iirc (because that's what the n66 can do), so I believe wireless-AC links can only be as fast as 866Mbps, which is WAY faster than my ISP package's 50/10Mbps. smooth, happy, cool, snappy...it's all good, both wired and wireless. I haven't been out in the yard to see if coverage is what it was before the change because it's been chilly, but I'm not overly concerned about my network reaching the street (and would rather prefer it didn't,) or the neighbours. I could easily upgrade my ISP package to a 1Gbps and I wouldn't have to change anything else. (I'm going to wait on an AX-router until the prices come down or I absolutely need one, but for right now, I'm absolutely satisfied)
Put good wifi where you use it and where it's needed and leave the rest of the airwaves/aether alone, I guess, is my/the premise rather than spraying it everywhere on the chance it might get used/be needed. Everything that doesn't move gets wired, the airwaves free up for what can't be, and the network....networks (lol) and ceases to be something to be tweaked/maintained/taken into consideration as often as some in this forum would have. Internet like air...breathe away!
@heysoundude, AiMesh is still quirky and disabling 2.4GHz band may break it in wireless configuration. I never checked the newer firmware releases, but not long ago disabling 2.4GHz on the nodes from the AiMesh screen was causing complete AiMesh lock up. The theory is one thing, but the reality is different. You have a single router only and disabling 2.4GHz radio is not a problem.
Going back to the OP's top post, my suggestion wouldn't work anyway, because they have an IoT swarm that relies on it. And Yes, I'd not be surprised if my suggestion also has negative effects on AiMesh.
But now my thoughts/perspective is out there for people to take or leave, and that means they'll have to ponder on them for their own situation.
You don't have to do that. The max link speed is 400Mbps at 40MHz wide channel to 2-stream AC client, about 200Mbps throughput or some more. Still faster than your WAN, but hurts your WLAN speed. You may get better range with 40MHz wide channel though, about 3dBm better SNR.
I did it to make sure the n66u is a happy camper, which it seems to be so far for about a week now. May not have -needed- to do it, but it seems to have kept things great or possibly made them better
Your choice, but you have restricted your entire WLAN (all devices) to about 200Mbps throughput (combined) for one single old client. This change may make a substantial difference if you have a NAS attached to your router and transfer files locally over Wi-Fi.
Going back to the origin of the thread - 200Mbit/Sec is more than enough for 2.4 in a 20MHz channel... most clients there are going to be N144 at best, N72 for single stream clients..
a 20Mhz 2.4 channel can cover a lot of range, and for many applications, this is more than enough.
@heysoundude is limiting his 5GHz throughput to AC devices for no good reason cutting the channel width from 80MHz down to 40MHz. This is not needed, both N and AC devices can coexist on 80MHz wide channel network with no issues. Obviously N devices will use 40MHz wide channel.
If I said to you that I am running an RT-AC86U in a detached house with not very thick stone walls, in an area with approx another 10 2.4Ghz networks visible from my neighbours, but very few of them on Ch11 (which I have set). This is a mixed network of 2 - 3 laptops and two smart phones (connecting at 5Ghz) and approx 30 other (mainly IOT Tasmota ESP) devices connecting on 2.4Ghz AND quite a lot of BT traffic for about 10 Xiaomi room temp sensors (all chatting to Home Assistant).
What would you suggest that I change in my current settings below?
I ask, because while a see a number of forum posts focused on certain settings, I don't think I have ever seen a conclusive best practice post that covers all 2.4Ghz settings in one.
Thanks!
I had lots of connection issues on ac86u also on ax55 and ESP8266 devices and Tasmota firmware. Yesterday I try to setup another tasmota esp8266 device and I couldn't connect to network, setup Draytek router for testing, tasmota device connect without any problem. Decided to try.
- disable DHCP server on asus router
- start DHCP server on other device in my case Synology NAS
Tasmota device connected without issues.
Worth to try.
