2nd IPv6 field LAN > DNS
Darkling
I have 2 Pi's whit AdGuard Home. Under LAN > DNS i can set 2x IPv4 and 1x IPv6.
@RMerlin would it be possible to add a 2nd IPv6 DNS field? So i can use both Pi's Whit AdGuard Home via IPv4 and IPv6.
You can set 3 IPv6 DNS servers under the IPv6 tab. Whether they are honoured or not is another matter. I still use a script to set the IPv6 server, not sure it's necessary in the latest firmware.
The router GUI doesn’t support it for some reason, but the firmware code already supports a second value. Login via SSH and run:
nvram set ipv6_dns2_x="pihole2 IP"
nvram commit
service "restart_dnsmasq;restart_net_and_phy"
@RMerlin would it be possible to add a second IPv6 DNS field under LAN>DHCP? Or is this maybe planned in the future?
Thank you for all your hard work. :)
