[ 3006.102_4 alpha Build(s) ] available build(s)
Strange ping via ipv6 works normally
When u have my own Adguard server should I select
Ipv6 connect to dns server automatically
No, if AdGuard provides you IPv6 addresses, use those so both IPv4 and IPv6 DNS connections are possible. Otherwise some queries may go to your ISP over IPv6.
That seems completely wrong. Why would you do that, specifically?
This is listed on Merlin's features web page if using DNS/TLS. Never understood why.
IMPORTANT: for DNS Privacy to work in IPv6, you must set IPv6 DNS Server in IPv6 page (not equivalent to add IPv6 DoT servers on the WAN -> Internet Connection page) to your router's LAN IPv6 Link-Local Address. You can find your router's LAN IPv6 Link-Local Address in System Log -> IPv6 tab. Link-local address starts with fe80.
Even so, robin put the WAN gateway IPv6 LLA as DNS, not the LAN IPv6 LLA. I still think that wouldn’t be necessary since IPv6 clients would still send DNS queries to the router’s GUA address and dnsmasq, and then dnsmasq would forward to Stubby on the loopback address if DNS Privacy is active.
That Wiki snippet was added by a user.
I have to put something in those fields or just set it to
Use ipv6 dns automatically, to no
And leave the fields blank
Beta builds is out:
@RMerlin
We can close this.
