380.57 port forwarding question
The traces do not agree with what you said. Seems you were requesting WAN over internal WiFi from your phone?
it was from LTE 100% , it shows coming from 192.168.1.1 because it hits a nat at wan and comes from my router, this is normal, look at other requests that came over LTE into wan to lan that look the same for web6000q
weird, so it looks like you do not have a default route. did you set a static ip on the wan page? there should be a place for a default gateway.
ifconfig to show the ip of your wan and lan interface on he r7000, iptables-save to see firewall and nat config, ip -4 route to see the routing table, but it looks like no default route is the problem
no static IP set on WAN page thats WAN IP setting and i dont want wan IP, there is nowhere to enter default gateway unless im selecting static ip and in that case its entering the wans gateway only
just now i tried enabling static ip set 192.168.1.1 255.255.255.0 192.168.1.1 default enable wan on 192.168.1.1 dns no bueno
ok, remove the WAN IP settings and SSH into R7000, use;
ip route add default via 192.168.1.1
192.168.1.1 should be erX IP. If this works, then because of your configuration you will probably need to add this to a script like /jffs/scripts/services-start
Btw, what's the IP range and mask for your VPN setup?
nothing special
vpn {
pptp {
remote-access {
authentication {
local-users {
username connor {
password ****************
mode local
client-ip-pool {
start 192.168.1.50
stop 192.168.1.60
dhcp-interface eth1
dns-servers {
server-1 8.8.8.8
local-ip 192.168.1.1
mtu 1492
admin@ERX:~$
okay. that explains. you're assigning the same subnet.
thanks for the little exercise.
Bravo to sinshiva!
still trying to figure out how to create script to run this command at boot
currently i got
#!/bin/sh ip route add default via 192.168.1.1
and save as defaultgateway.sh (all files setting notepad)
edit: ok i save with notepad++ and tried lowering command to second line still didnt work...
I would simply go back to WAN page and choose "Static IP" and put in 192.168.1.3 as IP address, 225.225.225.0 as mask, 192.168.1.1 as default gateway and 192.168.1.1 as DNS server1.
Then be done with it.
I tried that kvic it doesnt work cause those settings are for the wan ip not lan so they dont affect lan
For example if the default gateway was public like most isp default gateways are then it would cause problems using as internal default gateway
Your patch cord cable isn't connected to the wan port of Merlin router...?
try setting fake wan settings with the correct gateway like,
1.1.1.1
255.255.255.255
192.168.1.1
1.1.1.1
255.255.255.255
192.168.1.1
i tried it doesnt work
i just need help getting the script going
i have read merlins rules extremely carfully over 10 times and followed every rule, still doesnt work...
in /jffs/scripts/services-start
#!/bin/sh
command
then, to make it work
chmod a+rx /jffs/scripts/*
it will run near the end of the boot process
ok so this is my script
#!/bin/sh
im asuming thats ok
i saved it as test2.sh
created services-start folder in jffs/scripts
ran chmod command correctly
then rebooted
admin@R7000:/tmp/home/root# chmod a+rx /jffs/scripts/services-start/test2.sh
admin@R7000:/tmp/home/root# reboot
didnt work..
thinking i need to use .bash for the file or change something in my script?
i checked using merlins idea to test if the script is even running and its not so im stumped
Ok i tried makin file name services-start.sh and .bash neither worked... Odd
Ok i just did that, created the file named just "services-start" and ran the chmod command
However when i right clicked and checked properties for the file it still didnt say executeable
So i manually checked executeable in winscp and rebooted
And boom i got it :) thanks
