380.57 port forwarding question
Merlin sais to use notepaid++
Atleast for me notepad ++ does not save unix files without the .bash or .sh filenames
However i guess it would be easy to hit edit and remove it after
However what i did was create the file from win-scp
Not sure if chmod worked or me manually making it executable did but its working :)
it seems the chmod command was not working for me, dunno what i was doing wrong...
now that i got this working im getting this all over my logs
this and ntp problem
my next thing to solve....
Jul 31 17:04:42 kernel: TCP: time wait bucket table overflow
ugh why is ntp not working i have default gateway now...
Jul 31 17:08:12 hour monitor: ntp is not syn
Jul 31 17:08:42 hour monitor: daemon is starting
Jul 31 17:08:42 hour monitor: ntp is not syn
In some applications, surrounding the file name with double quotes stops the automatic addition of an unwanted extension.
For example, save as
"services-start"
( Unfortunately I don't have notepad + + here to try it ).
Cool thanks polarbear i will try it when im home
