Anybody still having problems compiling hnd libconfuse? It has no makefile.in file.
They should normally be automatically generated, but Linux autoconf being the random PITA that it is, it seems like it doesn't always do so... I'll commit the existing Makefile.in files to Github later.
I compiled your latest git push and it worked. Thanks for getting the bugs fixed. I'm running the build now. I notice I have to delete the release files before compiling and git resetting cuz make clean does not clean the necessary folders/files.
The HND build environment was hacked together by Asus, as Broadcom's own build environment is quite different. So, cleaning up won't work properly for instance.
Always work with two separate copies of the repo. First one is the one you keep up-to-date with Github. Then, use rsync to copy it to a second directory, and always build from that second copy.
Is this known limitation or is it bug?
I set up two .ng directories and am using rsync. Works well. Thanks. That way I don't have to work so hard.![]()
This is the case for me as well on my RT-AC66U_B1 running the 68U firmware. I even went back to 384.5 to test this and got the same result where the ports seem to be backwards.
Code:nvram show | grep _speed size: 58010 bytes (7526 left) usb_path2_speed=480 usb_path1_speed=5000
Code:dmesg | grep usb usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb usb usb1: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values [xhci-hub] usb2mode:[0] usbcore: registered new interface driver cdc_acm usbcore: registered new interface driver asix usbcore: registered new interface driver cdc_ether usbcore: registered new interface driver rndis_host usbcore: registered new interface driver cdc_ncm usbcore: registered new interface driver cdc_wdm usbcore: registered new interface driver qmi_wwan usbcore: registered new interface driver cdc_mbim usbcore: registered new interface driver usb-storage usbcore: registered new interface driver usblp usb 1-1: new SuperSpeed USB device using xhci_hcd and address 2 scsi0 : usb-storage 1-1:1.0 usb 2-2: new high speed USB device using ehci_hcd and address 2 scsi1 : usb-storage 2-2:1.0
| Thread starter | Title | Forum | Replies | Date |
| S | 102.7 Alpha Builds available | Asuswrt-Merlin | 150 | |
[ 3004_388.11 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 36 | |
[ 3006.102.6 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 206 | |
[ 3006.102.5 alpha Build(s) ] available build(s) | Asuswrt-Merlin | 111 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
