somms
Will Merlin compile OpenVPN 2.4.8 released last week into the current stable build or would we have to wait on 384.14 alpha build to become stable before including latest OpenVPN build? Thanks!
I answered your cross post a few seconds ago. Cross posting can confuse people, try to only post the question once, please.Will Merlin compile OpenVPN 2.4.8 released last week into the current stable build or would we have to wait on 384.14 alpha build to become stable before including latest OpenVPN build? Thanks!
Nov 1 15:11:02 ovpn-client1[5471]: OpenVPN 2.4.8 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Oct 31 2019
Nov 1 15:11:02 ovpn-client1[5471]: library versions: OpenSSL 1.1.1d 10 Sep 2019, LZO 2.08
Merlin updated to OpenVPN 2.4.8 (you can see it on git) . I use it ( compiled Merlin build myself ) . I guess it will be on the next build.
https://github.com/RMerl/asuswrt-merlin.ng/commit/e411bb0c5d625d32a50675b27b7e5fa5b84eeb67
Code:Nov 1 15:11:02 ovpn-client1[5471]: OpenVPN 2.4.8 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Oct 31 2019 Nov 1 15:11:02 ovpn-client1[5471]: library versions: OpenSSL 1.1.1d 10 Sep 2019, LZO 2.08
Yep ,Anyone with a 86u, can you describe what problems you're experiencing?
384.13 is the most stable firmware so far.
And lots of "modprobe missing modules" messages in the log.
Hold on... 384.13 is a release version, 384.14 is an alpha testing version. Can't compare the two for stability.
I do not know if it's just me?."Your dhcp does not function properly" everytime after a Factory Reset with .14A1-2, router must be reboot to get an ip
Guess what, that's what I did. Cleaned everything including nvram, like I wrote. In the alpha I couldn't make it work.Importing any setting is not advised when having trouble. Try the flash then factory reset, then manual configure from there.
Finaly i am not aloneIt was a disaster. So I'm back on .13 till .14 is released.
It seems no one is trying to do FRD with AC86
I cant say its a disaster on my side,this is only the first time I have this kind of message with this model after a FdR "Your dhcp does not function properly" .This is not a big problem, anyway I always reboot after fdr and reconfigI do. And I don't experience any "disaster" with my RT-AC86U
it is done , there is no problem with the wifi, this version is very stableMake sure you properly reconfigure it afterward, especially wifi,
I do. And I don't experience any "disaster" with my RT-AC86U. I'm currently streaming a podcast from my tablet connected to my freshly resetted RT-AC86U.
Make sure you properly reconfigure it afterward, especially wifi, since the US model seem to have gained DFS support now. So if you leave it on Auto Channel and you have clients that have troubles with DFS channels, it may cause issues. This is unrelated to the firmware itself.
I have bcm kernel lines
I have ssh issues on restore.
. I have ntp issues using skynet dirty flash and restore.
Please list your settings to make .14a2 work flawlessly...
the dcd taint is also an issue from AIProtect.
Welcome To SNBForums
