huzaimie360
my wan is PPPo
so far playing the division PVP in the darkzone killing agent, my bullet hit registration are on the spot no lag at all so far..
Running alpha 2 on my RT-AC86U, just to make sure you are aware the dcd crashes are back.
I implemented something similar in sh for Skynet
Had fun working with the IPv6 support?
I spent the whole day working on it yesterday. Trend Micro's proc interface truncates the last two bytes of the IPv6 (in addition to formatting it in a very weird way). So I have to fake the last two bytes of the address for now...
80+ characters for the combined IP fields doesn’t fit so great in an SSH terminal with all the other data which is also a PITA.
I like the previous text in the colored box for quicker identification/association with the QoS categories. The left-justified color box is too far from the text (at least I personally need to scan left-to-right/right-to-left to see them both).
But does that mean we could sort by color so that all like applications within a category are together?The square version is easier to quickly identify, but makes it impossible to sort by application name (because I have to put the CSS before the actual text, that means the sort will be done based on the CSS text rather than the Application text).
<span class="cat0"...
<span class="cat1"...
<span class="cat2"...
etc...
Jan 14 19:09:49 WLCEVENTD: eth5: Disassoc 00:0A:F5:FD:05:44
Jan 14 19:09:53 WLCEVENTD: eth5: Assoc 00:0A:F5:FD:05:44
Jan 14 19:09:53 kernel: [BLOCKED - INBOUND] IN=ppp0 OUT= MAC= SRC=176.119.4.35 DST= LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=38235 PROTO=TCP SPT=57328 DPT=9283 SEQ=518387245 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan 14 19:10:12 kernel: dcd[21178]: unhandled level 3 translation fault (11) at 0x00000000, esr 0x92000007
Jan 14 19:10:12 kernel: pgd = ffffffc0017a8000
Jan 14 19:10:12 kernel: [00000000] *pgd=000000001117c003, *pud=000000001117c003, *pmd=00000000150d6003, *pte=0000000000000000
Jan 14 19:10:12 kernel: CPU: 1 PID: 21178 Comm: dcd Tainted: P O 4.1.27 #2
Jan 14 19:10:12 kernel: Hardware name: Broadcom-v8A (DT)
Jan 14 19:10:12 kernel: task: ffffffc014796ac0 ti: ffffffc01e95c000 task.ti: ffffffc01e95c000
Jan 14 19:10:12 kernel: PC is at 0xf7356f44
Jan 14 19:10:12 kernel: LR is at 0x1dc74
Jan 14 19:10:12 kernel: pc : [<00000000f7356f44>] lr : [<000000000001dc74>] pstate: 600e0010
Jan 14 19:10:12 kernel: sp : 00000000ffd7cb48
Jan 14 19:10:12 kernel: x12: 000000000009ff10
Jan 14 19:10:12 kernel: x11: 00000000f65ff024 x10: 00000000000a02b4
Jan 14 19:10:12 kernel: x9 : 00000000f65ff898 x8 : 00000000000a076c
Jan 14 19:10:12 kernel: x7 : 00000000f65ff8d0 x6 : 00000000000a0766
Jan 14 19:10:12 kernel: x5 : 0000000000000000 x4 : 00000000f65ff87c
Jan 14 19:10:12 kernel: x3 : 0000000000000000 x2 : 00000000ffd7cb24
Jan 14 19:10:12 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Jan 14 19:10:52 kernel: dcd[21867]: unhandled level 3 translation fault (11) at 0x00000000, esr 0x92000007
Jan 14 19:10:52 kernel: pgd = ffffffc011cfb000
Jan 14 19:10:52 kernel: [00000000] *pgd=0000000011379003, *pud=0000000011379003, *pmd=0000000014661003, *pte=0000000000000000
Jan 14 19:10:52 kernel: CPU: 1 PID: 21867 Comm: dcd Tainted: P O 4.1.27 #2
Jan 14 19:10:52 kernel: Hardware name: Broadcom-v8A (DT)
Jan 14 19:10:52 kernel: task: ffffffc011177480 ti: ffffffc0157e4000 task.ti: ffffffc0157e4000
Jan 14 19:10:52 kernel: PC is at 0xf74f5f44
Jan 14 19:10:52 kernel: LR is at 0x1dc74
Jan 14 19:10:52 kernel: pc : [<00000000f74f5f44>] lr : [<000000000001dc74>] pstate: 600e0010
Jan 14 19:10:52 kernel: sp : 00000000ffe21fc8
Jan 14 19:10:52 kernel: x12: 000000000009ff10
Jan 14 19:10:52 kernel: x11: 00000000f697c024 x10: 00000000000a02b4
Jan 14 19:10:52 kernel: x9 : 00000000f697c898 x8 : 00000000000a076c
Jan 14 19:10:52 kernel: x7 : 00000000f697c8d0 x6 : 00000000000a0766
Jan 14 19:10:52 kernel: x5 : 0000000000000000 x4 : 00000000f697c87c
Jan 14 19:10:52 kernel: x3 : 0000000000000000 x2 : 00000000ffe21fa4
Jan 14 19:10:52 kernel: x1 : 000000000007c674 x0 : 0000000000000000
Thx and sry, for not reading the other posts, i don`t have the time right now to do that, i need to leave! So, im really sry for posting this issue again.Yes, extensively discussed, was mentioned just a few posts above.
Has anyone else had trouble with the client list on the network map page not showing all connected devices? It will refresh and then still not show all devices. Right now mine shows 2 devices, I have at least 14. Now I know @RMerlin has no access to that code but, does anyone else have this issue before I reset?![]()
Same thing with my Ac86u.Has anyone else had trouble with the client list on the network map page not showing all connected devices? It will refresh and then still not show all devices. Right now mine shows 2 devices, I have at least 14. Now I know @RMerlin has no access to that code but, does anyone else have this issue before I reset?![]()
Anyone else?That is happening for me. The count is also wrong. It stops at 19, yet there are over 30 devices connected and functioning properly. Since it appears to be only a GUI problem, I've not worried about it.
I have been running 384.9_alpha2-g2ee0afa1c on my RT-AC3200 for about 8.5 hours.
Anyone else?
Welcome To SNBForums
