3G usb adapter TPLink MA180 on v378.56_2 not working
Khurram
I am trying to get the 3G usb adapter TPLink MA180 work on Asuswrt-Merlin but not having any success. The service provider just requires an APN name (no authentication) and that is what I have entered in the "USB Modem / USB Tethering" page. But I think it is not even dialing as I dont see any pppd entries in the syslog. From the log, it shows that the adapter is being detected:
Aug 1 05:00:15 hotplug: Got net usb0, vid 0x2357, pid 0x201.
Aug 1 05:00:15 kernel: usbcore: registered new interface driver usbserial
Aug 1 05:00:15 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
Aug 1 05:00:15 kernel: usbcore: registered new interface driver usbserial_generic
Aug 1 05:00:15 kernel: drivers/usb/serial/usb-serial.c: USB Serial Driver core
Aug 1 05:00:15 hotplug: Got net usb1, vid 0x2357, pid 0x201.
Aug 1 05:00:15 hotplug: set net usb1.
Aug 1 05:00:15 kernel: drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-port)
Aug 1 05:00:15 kernel: option 1-1.1:1.0: GSM modem (1-port) converter detected
Aug 1 05:00:15 kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
Aug 1 05:00:15 kernel: option 1-1.1:1.1: GSM modem (1-port) converter detected
Aug 1 05:00:15 kernel: usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB1
Aug 1 05:00:15 kernel: usbcore: registered new interface driver option
Aug 1 05:00:15 kernel: drivers/usb/serial/option.c: USB Driver for GSM modems: v0.7.2​
I tried the MA180 on another router running OpenWRT and it worked after a few attempts. The main difference is that OpenWRT creates 3 ports: /dev/ttyUSB0-2 and pppd connects on /dev/ttyUSB2. In Asuswrt-Merlin, only /dev/ttyUSB0-1 ports are created. gcom info -d <dev name> gives error on both these ports also. Is there something wrong with the detection of the MA180?
I have been searching for anwers to my problem. Over at usb-modeswitch forums, there is an old thread on the MA180 ( http://www.draisberghof.de/usb_modeswitch/bb/viewtopic.php?t=942). It also indicates that the modem is at /dev/ttyUSB2 which is not being created. In fact, the thread indicates that 4 devices should be created for the MA180. Is there a way to override the detection of the MA180 device ids and force the creation of /dev/ttyUSB0-2 ports?
Thanks.
