Read on SmallNetBuilder
Achieving the maximum 1148 Mbps 2.4 GHz rate requires a device support 1024 QAM modulation, 40 MHz bandwidth and four streams, as shown in the table below
Next up is a look at the effect of 160 MHz networks. One source has told me 80+80 is dead for AX. The RF design is too much of a pain in the butt and costly. Contiguous 160 and DFS support will be commonplace.
The "80+80 MHz" statement was opinion, not necessarily fact. But it was offered by someone who has access to more industry information than I have.What about regions where there aren't enough channels to make up 160MHz of contiguous bandwidth? At least based on the 802.11ac channels, there are countries like Japan, China, Korea and oddly enough, Switzerland that doesn't offer any 160MHz channels and some have no 80MHz channels either. This suggests 802.11ax will have zero net benefit for those countries.
Perhaps. But didn't you already say "Getting 40MHz channels in most places these days is a challenge"?There can still be benefit of 11ax in 40MHz channels, similar to the benefits noted with 11ac in the same conditions.
Yup. We'll be looking at this. Just waiting for real product to ship. It's gonna be later vs. sooner.11ax and legacy devices and overlapping BSS's
You're right. I should not have assumed you were just referring to 2.4 GHz. Yes, 40 MHz bandwidth in 5 GHz seems to be more the norm.in 5GHz, should be fairly easy
Do you think the average (any?) consumer will run their AX router in 40 MHz mode?![]()
This situation has nothing to do with 11ax.I just want to see more flexibility on products that are actually sold by different manufacturers. Right now I have two AC routers and 1 range extender (won from a competition here on SMB) and none of them have a matching way to set 5ghz channels.
My Netgear R7000 doesn't work with valid DFS channels in the UK.
My BT supplied modem/router only has a choice of two.
My Asus range extender lets me set practically any channel.
I would love if it was just standardised and made more straightforward so it was less hassle choosing which channel, upper/down etc
Do you guys know what I mean?
Yeah I realise its got nothing to do with AX but I just wish there would be focus on more standardisation rather than new standards completely, if you browse several GUIs of AC routers its confusing which channels they are going to use. Its far more complicated than N where you can just choose a number, now you never know what you get when you set your AC channel when using anything other than 20mhz bandwidth.This situation has nothing to do with 11ax.
DFS is still not commonly supported by consumer WiFi products. It requires an extra set of testing at least in the US for separate FCC certification. Not all manufacturers want to go through that.
DFS will be pretty much required for viable 11ax products if they want to support 160 MHz bandwidth.
Welcome To SNBForums
