InkyRag
I recently replaced my router and access point with a couple of ac68u's. I have my 5Ghz channel widths set to 40 MHz and N + AC as it is more stable with our cell phones. This is the same settings used with my other equipment. Issider shows the channels as only 20 MHz wide.
I have tried other settings with the same results. This is not specific to Asuswrt-Merlin because I had the same results with the stock firmware.
Any idea what is going on?
Answer: It appears that I had and issue with Inssider, which was previously working. I just upgraded to the pay version of Inssider and I am now seeing 40 Mhz width channels and the correct connection speeds.
