...and here I'm wondering how any ads got blocked when ad-blocking was set to off.It's ok, I've sorted that out by enabling the adblock
I understood your view about not complicating your script. You would need it to check that entware was installed, install pixelserv, set its config file for the custom IP, for the time stamp correction, change post-mount to include entware and ab-solution, change wan-start to add the bridge, and then deal with the certificates. That's a lot, and maybe it would be enough just to display a page with instructions, or maybe a submenu that checked each step as the user did it outside the script.No, not automatically. You will have to configure pixelserv-tls yourself to do that.
But since you mention it, I _may_ have reconsidered my opinion about not fully supporting (and installing and configure) pixelserv-tls as part of AB-Solution.
And _maybe_ there's a sizable and interesting part of code in my local ab-solution.sh that might be of interest to some.
Maybe.
minor issue w/whitelist.
i added an entry princessauto.com , i used "p" to update the whilelist but the "reviews" tab for products in princessauto.com will not display, the reviews are not external links
if i disable adblocking the princessauto page will display correctly
thx, it worked, how did you find that url....in the page source code?remove princessauto.com and add this to the whitelist :
display.ugc.bazaarvoice.com
I've just tried it and the review now shows up
cool, i new that log file was good for somethingIt's all in the wording, just kidding. If you start ab-solution menu and type "f" (follow the log file) then press enter then go to your website's product page, the adblocker will then show you a list ads it has blocked on that specific page. I just then entered a couple of block ads addresses to the whitelist then narrowed it down.
Adblocking on and off does that.Hi
I have a questions...
How i can disable or then enable AB-Solution ?
How i can test it and see in log that example site is ok block:
honor.agitaattori.fi/rncbu3.html
Thread starter | Title | Forum | Replies | Date |
C | Is there any easy solution in Merlin for a VPN server that is hard to block/detect? | Asuswrt-Merlin | 15 | |
[SOLUTION] WAN_Connection: ISP's DHCP did not function properly | Asuswrt-Merlin | 6 |
Welcome To SNBForums
