Same price as before: Free as in free beer.I hastily read that AB-Solution will cost. How much will it cost roughly?
Thanks so much!
Based on the likes I'll likely go with these:How about "Basic""Standard" and "Pro"?
AB-Solution 4.0 Basic
AB-Solution 4.0 Standard
AB-Solution 4.0 Pro
However, the distinction between Basic and Standard is not clear with these names. Is there a better word for Standard? Thesaurus and synonyms fail me in finding a better name for it. Short and to the point would be perfect!
Read the post again where I listed the features of the three versions.Perhaps there should only be two. Standard would be Basic. Eliminates the naming problem.
AB-Solution 4.0 Pro
Just a thought!
That's the day after tomorrow or in three days, depending how you define Christmas.Is the 4.0 Pro version available for Christmas already?![]()
Sounds good to me:Perhaps "Lite". If I understand it, this will be a no-entware, no-pixelserv, no WebUI version.
Then Standard will be most single installs.
Pro will be for people managing multiple routers?
Sounds good to me:
AB-Solution 4.0 Lite (no pixelserv)
AB-Solution 4.0 Standard (ps and WebUI)
AB-Solution 4.0 Pro (ps and WebUI, manage installation on several routers)
I have decided that all installations will require Entware and install it unceremoniously if not present, even the basic Lite version.
This way I can handle upgrades a lot better. And it allows for consistent system wide paths and the simple start and manage command of 'ab-solution' for all.
The install process is simplified and completely different in AB4. I need to know what you plan to do at the beginning so I can install accordingly.Wow! You are truly amazing! But, I not understand one thing: if AB-Solution is free, why are there more version? Only for features?
For example:
If I would like to install Ab-solution without pixelserv, I will install basic version.
The way of thinking is correct?
Thanks so much as always!
I'm moving on in the right direction with AB-Solution. There will be some tears and complaints but I have to get ahead and do what I long since wanted to do and many users expect and pleaded with me. I had unpleasant arguments with users why AB is not more portable.So basically what I would like to know. How would it affect me? If you would be pushing Entware in your future updates, would I need to do the whole procedure such as turning off Optware, getting a hard drive ready for it. Or would it install in my 8GB USB stick I'm using now and if it did, would it affect performance? My questions may seem newbish and maybe stupid. I've been following this forum since the day I found out about Merlin and I'm updated on information, but when it comes to technical info sometimes, I might feel a bit lost.
Welcome To SNBForums
