AB-Solution - The Ad Blocking Solution
Why am i getting this?
@RT-AC3100-5C88:/tmp/home/root# /home
-sh: /home: Permission denied
What are you trying to do? /home is not a program, therefore typing that in a shell won't do anything.
Also i installed AB solution and i rebooted the router. It would not find AB Solution install on the router via SSH. Any ideas?
Without pixelserv, it's:
sh ./ab-solution.sh
With pixelserv it's just:
ab-solution
It seems one of the site hosting hosts file is down. Got the following after Ab-Solution tried to update the blocking file:
--------------------- Message ----------------------
Hosts file download failed or file is not hosts
file, using local backup file instead.
Run [u] to manually update.
I am using shooter40sw+. The manual update gets error while updating file 6:
 getting hosts file 6, preprocessing file:
 https://www.malwaredomainlist.com/hostslist/hosts.txt
 file 6 download failed or file is not hosts file, using backup file
AB 3.11.1 has the malwaredomainlist.com host set back to the HTTP protocol. Run b and re-select your blocking file, it will then write the non-HTTPS URL.
Check first with c, it shows the config file, the hosts_list is near the top. Then run b and check again with c.
I apologize if this is the wrong forum. I am looking to block torrents and I do realize that this most excellent software is about AD blocking.
Does AB-Solution have torrent blocking capability out of the box? Or, would someone suggest a solution to block torrents? I assume I could manually update the blacklist with a list of torrent trackers but would like an easier solution.
No luck. Even after updating blocking file using b, the files stay https.
Do you use a custom list?
If not, change to another type, then back. Only the malware domain was changed back to HTTP, most others still use HTTPS.
AB blocks domains, and outbound only. If that is what you want then AB will work for you.
I'm sure there are readily available comaptible lists to use out there. You could include such a list in the custom blocking file.
No I don't use any custom list.
Anyway I went to Medium+ and reverted back to shooter40sw+ list. Then just to be sure, I choose AdsBeGone+ list and reverted back to shooter40sw+ list. For both cases, the url for malwaredomainlist.com remained same with https but this time was successful.
-                            100%[==============================================>]  35.92K   209KB/s    in 0.2s
 processing file 6 done
The blocking file settings from c for shooter40sw+ list after reverting back,
 # Blocking file settings #
 hostsFileType="shooter40sw+"
 addnHosts="on"
 hostsFileUpdateDay="Tuesday"
 dayOfWeek="Tue"
 updateHour="8"
 hostsFileLastRun="Jan 09 17:37:17"
 previousLastRun=""
 hosts_list="http://someonewhocares.org/hosts/zero/hosts
 http://winhelp2002.mvps.org/hosts.txt
 https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext&useip=0.0.0.0
 https://hosts-file.net/ad_servers.txt
 https://hosts-file.net/grm.txt
 https://adaway.org/hosts.txt
 https://hosts-file.net/emd.txt
 https://hosts-file.net/exp.txt
 https://hosts-file.net/hjk.txt
 https://hosts-file.net/mmt.txt
 https://hosts-file.net/psh.txt"
 addnHosts="on"
 dayOfWeek="Tue"
 updateHour="8"
 previousLastRun=""
I'll check in the morning.
 addnHosts="on"
 dayOfWeek="Tue"
 updateHour="8"
 previousLastRun=""
If you enter s, what are the version numbers shown?
For 3.11.1 it's:
 Infos about AB-Solution  The Ad Blocking Solution
 App Name:            AB-Solution
 App Version:         3.11.1 (3.11.1)
 Development Version: 1
 Script Name:         ab-solution.sh
 Release Date:        20171211 (YYYYMMDD)
Both, the release and beta channel have the correct HTTP listed at line 2087 in ab-solution.sh:
# list of standard blocking file types
hosts_list1='http://someonewhocares.org/hosts/zero/hosts
https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext&useip=0.0.0.0'
hosts_list2='
https://hosts-file.net/ad_servers.txt'
hosts_listtwo='https://hosts-file.net/ad_servers.txt' # same as 2, no empty first line as 1, for file count
hosts_list3='
https://hosts-file.net/mmt.txt'
hosts_list4='
https://hosts-file.net/hphosts-partial.txt
http://support.it-mate.co.uk/downloads/hosts.txt'
hosts_list5='
https://adblock.mahakala.is
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts'
hosts_list6='
https://adaway.org/hosts.txt'
hosts_list7='
http://www.malwaredomainlist.com/hostslist/hosts.txt'
if [ "$addnHosts" = "on" ];then
addn_hosts='
https://hosts-file.net/psh.txt'
hosts_list3='
https://hosts-file.net/grm.txt'
else
addn_hosts=
fi
For 3.11.1 it's:
hosts_list2='
hosts_list3='
hosts_list4='
hosts_list5='
hosts_list6='
hosts_list7='
addn_hosts='
hosts_list3='
else
addn_hosts=
fi
Very weird! In my script it's still https.
Output from 's':
And from the ab-solution.sh,
hosts_list2='
hosts_list3='
hosts_list4='
hosts_list5='
hosts_list6='
hosts_list7='
https://www.malwaredomainlist.com/hostslist/hosts.txt'
Output from 's':
hosts_list2='
hosts_list3='
hosts_list4='
hosts_list5='
hosts_list6='
hosts_list7='
I believe I silently updated it, but announced it in this thread somewhere.
Run 1233 to re-download all AB-Solution files to be on the latest version(s).
I run one of my 2 OpenVPN servers on TCP port 443. So I disable pixelserv if I want to be able to connect to that server.
I presume it comes down to that choice: the Ovpn server on port 443 or pixelserv if I want them both running on the same device (the router)? And if I keep pixelserv permanently disabled, what would that stop from happening, other than the blank space instantly displaying? (I get the feeling there’s much more to pixelserv than I’ve so far grasped.)
Read the few posts after it too.
You may be able enumerate some of the torrent sites and block the HTTP/HTTPS and tracker traffic, but you won't be able to block actual BitTorrent traffic using the AB mechanisms. It's challenging for full blown DPI systems too unless you implement massively draconian port blocking (drag-net style.)
/dedd
As long as they use domains exclusively, yes blocking outgoing requests will work. Just as with any domain hijacking/DNS poisoning.
I believe it is good for us that consumer router capabilities are limited. Imagine if common routers were able to do even a minimal DPI on the traffic seen. This would open up endless possibilities for hackers.
