AB-Solution - The Ad Blocking Solution
Two problems:
1) When I launch "cu", it returns the following error:
Error: Received incomplete version info file from ab-solution.info
What do you want to do?
2) I add "googleadservices.com" in white list, but AB still blocks it
Website migration is under way
ab-solution.info moves to a new server, from IP 80.74.156.155 to 80.74.145.140.
If you no longer see the announcement on the website, your are viewing ab-solution.info on the new server.
The DNS propagation will take about 24 hours worldwide, 2 hours in Switzerland.
Note that the secure website over HTTPS will not be available on the new server until I can properly enable the SSL certificate on it.
My Hoster has manually intervened, it will sort itself out in the next few minutes.
Two problems:
Try the cu again, but do this before starting the AB UI so that Dnsmasq flushes its cache:
service restart_dnsmasq
With all the recent USB file and disk errors, I felt a FAQ entry on the AB-Solution website is in order.
How to fix disk / USB key errors
Thank you. Having trouble getting to that page. Clicking the link or copy / paste the url (https://www.ab-solution.info/faq-reader/how-to-fix-disk-usb-key-errors.html) takes me to the home page (https://www.ab-solution.info/). I tried the FAQ and could not find it. and search on your site does not give me any results. Neither AB-Solution of Skynet is blocking me. :D I have no idea why.
I made a server change yesterday.
On the home page on the old server is an announcement of the change. There is none on the new server.
Clear your cache in the browser/OS.
Edit: The page you're looking for is only posted on the new server.
Cleared browser cache and cookies, then used Shift F5 on the site, cannot get to the url. Must be some issues with the DNS updates here in the western USA. No big deal, I can wait until the changes migrate. Still seeing this:
November 13 2017
Website migration is under way.
If you no longer see this announcement, your are viewing this website on the new server.
This article is now also on the old server.
Are you still seeing this on https://www.ab-solution.info/:
November 13 2017
I'm not even sure that Bitcoin
November 13 2017
No, it is finally cleared from the ab-solution home page as of 7:58 am PDT
It was still showing last night at 23:02 pm PDT.
Thank you.
Thank you.
Seems Domain registrars are right when they say it could take up to 48 hours for changed DNS server settings to propagate.
Around here it's one to two hours if you use the DNS servers from your ISP and have the domain registered in the same country.
