Absolutely unable to add new XT8 node to existing XT8 network. Any ideas?
Any tips on updating the firmware on a node that is not connected to the system/internet, or advice on my situation in general?
Set it up as a router with different SSID, update the firmware manually. Make sure you pick the right firmware. This model has V1 and V2 hardware revisions with different firmware files. You also may need to upgrade it to specific firmware version first - read older firmware release notes.
I'm having this same problem. I followed chippy's process but was still unable to add a new node. One of the possible issues from the error message was that the firmware isn't up to date. How can I update the firmware if I can't connect the node? I thought about setting up this new node as a new router but I had such a hard time getting my main router and first node to work, I don't want to risk them going offline. Any tips on updating the firmware on a node that is not connected to the system/internet, or advice on my situation in general?
Save the firmware file to your computer. Power on the AiMesh node and connect your computer directly to it via Ethernet cable or Wi-Fi. Access the node’s web interface by entering its IP address in your browser. Select the firmware file you downloaded and upload it to the node. Wait for the process to complete. The node will reboot once the update is finished.
Thank you so much for this! It worked for me in 2024. My only hiccup was the instruction "Change Connection Priority to Auto." It was grayed out under the management tab of the node I was trying to add. I had to uncheck the Ethernet Backhaul Mode setting under AiMesh and the System Settings tab before the option to "Change Connection Priority to Auto" was available.
