twitchyzero
Did anyone try that firmware yet? For many people, availability and quality of 3rd party firmware makes or breaks the deal...
agreed...without tomato or merlin's cfw it's kind of a deal breaker.
I am running VPN client
First, you need to establish a baseline:
- Naked (no VPN) Internet speed on wired client - measure using testmy.net
- Internet speed on a reasonably fast system with VPN client installed and running
- same, but this time the router runs the VPN
if your internet speed is <25Mbps, I expect R7000 with stock clocks (1000,800) should be able to handle it with tolerable drop - let's say 22? The router may get warm - I do not know how good is Netgear's cooling)
If you are on much higher speed - like 100Mbps - the impact is hard to predict, but I do expect it to be very noticeable...
Thanks for your insight. You say 22, so are you saying that a router at 25Mbps or just under would only drop 10-12%? That's really not bad at all. What sort of hit do you take on your AC56?
My speeds on average push anywhere between 75-100Mbps measured at speedtest.net so I was thinking I'd keep a portion of my traffic unencrypted that comes in through my feed and VPN everything else if the hit is too considerable. But that's not as secure or preferable as being able to op completely from VPN. 10-12% I'd take gladly. 50% ... probably not.
Also the firmware has big impact on performance too - if you are considering R7000, that limits your FW choice to OpenRouter - and I have no idea how fast is that firmware. Big part of the problem is that OpenVPN client (used on routers) is only using single core and that limits performance on dual core CPUs big time...
Why wouldn't dd-wrt be developed for the R7000? Of course right now it's too new, but I would assume that porting it would be in the works after it comes out and the source is released.
I guess I'm not crazy then.
This screech, static, whatever sound is sort of annoying.
Here's a link to the sound file that describes the sound I hear:
http://www.dslreports.com/r0/downloa...b/IMG_0073.MOV
Seems like this is plaguing Broadcom setups. Netgear said that they tested this when I reported it, but they didn't hear any sound. I just wonder if they weren't listening close enough or not.
My point: it is unknown at this point what is the performance of DD-WRT vs. stock. Simply not enough R7000 are sold yet and not enough people are playing with them... and yes, VPN client support and performance is a very important factor in my buying decision.
During your review, did you get a sense for which router produced less heat, and did you plug either unit into e.g. a kill-a-watt at idle? I haven't found any information about power consumption for the R7000 so far and I'd love to compare before making a purchase decision in the next few days.
Just did some testing with the VPN server on the R7000,
My speeds are 39-41mbit/s for both uploads and downloads.
If I telnet into the router and run top, the VPN server is only using a single core
when idle or very little traffic, the CPU usage is 1%
and at full saturation, (transferring data over the LAN between 2 computers) it maxes out 1 core.
If the VPN service was allowed to use both cores and probably just run at a lower priority to avoid lagging the router, it could potentially double the VPN throughput
Hopefully smallnetbuilder can do a proper test of the VPN, and possibly also retest the 256 QAM since it is now confirmed that the router can report the link rate.
weird how the DD-WRT page doesn't list QoS?
Yeah I saw this CFW out of box support...I'm curious of Merlin or Shibby's Tomato will eventually make it to the R7k.
Do you have any experience with the cloud-based QoS yourself Tim?
merlin...what are the chance of you bringing merlin to the R7k given that you will be working on the ac68u? Would same chip but different radios/firmware make it very difficult to code over?
I have mostly given up on 3rd party firmware, the drop in general routing performance, and the large drop in wifi performance, have made them less appealing.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
