omiez
Hello
I am running 384.14 on my AC86U and i see a very high ram usage, at the moment i am writing the router is using 475MB.
Is this normal or did i something wrong? I enabled DL Master , Media Server and Network Place. Beyond that i have a few rules in Port Forwarding and 3 Fixed Ip´s.
I think that 475MB used of 512 are very much but help me out and tell me if this is normal.
Would it be helpful to use a swap file and if yes how and where (HDD or External USB Drive) would you recommend configuring it?
Thank you in advance.
