AC87U disconnection on 2.4ghz.
Been following this thread - try setting the 2.4GHz radio to B/G/N mode, rather than auto - auto includes some extra parameters in the beacon frames to support VHT20/VHT40 (TurboQAM, aka QAM256), and this can cause issues with some clients that may not expect those parameters...
See if that helps...
Done that! No problem on Channel 6 at all. However, Channel 1 disconnects every few hours (not only media bridge, I noticed it dc on my netbook too). Atleast it works as long as I use Channel 6.
The problem atm is 5ghz disconnecting every few seconds. :( I tried using N only instead of Auto too... I am really trying hard to get it to work, because all my devices atm are on 2.4ghz and obviously its shared... When people stream between computers my ping is a lil bit higher (well actually its jitter).
