Is there any issue with download master? I tried both stock firmware and merlin and magnet downloads just hang. Error log shows
Sep 20 15:20:43 Samba Server: daemon is started
Sep 20 15:24:31 transmission-daemon[30092]: Couldn't bind port 52000 on ::: Address already in use (Is another copy of Transmission already running?) (net.c:371)
Sep 20 15:24:31 transmission-daemon[30092]: UDP Failed to set receive buffer: requested 4194304, got 245760 (tr-udp.c:78)
Sep 20 15:24:31 transmission-daemon[30092]: UDP Failed to set send buffer: requested 1048576, got 245760 (tr-udp.c:89)
Sep 20 15:28:33 kernel: get_file_caps: get_vfs_caps_from_disk returned -22 for /opt/etc/downloadmaster/downloadmaster/dm_print_status.cgi
Using the interface it says hashing, and doesn't allow to delete a torrent after adding.
I tried two different type of USB device. It was working fine with N66U.....
