Might be worth trying the new SSID if it isn’t fixed with a new release (just noticed that 384.18 is available) thank you. I’m not using smart connect as I like to be able to manually decide the devices that connect to 2.4 and 5GI desactivated smart connect, and reputted two differents ssid for each frequence (2.4 et 5G). Less problems. (smart connect not reliable?)
That’s great, I’ll try another upgrade with that setting disabled. ThanksI have maybe found the option which was causing me problems: WMM APSD. I desactivated it on the two frequencies and no more problem for the moment. (surely not a problem, normal with this option activated)
I have too always micro deconnexions-reconnexions on the lan, maybe linked to this problem? always not solved?
Welcome To SNBForums
