Add Clouflare for Families to DoT list
Just add it manually yourself. RMerlin has stated many times that's he's not in favour of creating endlessly increasing lists, especially when it's trivial for the user to enter the information themselves.
Yes, my appologies. I had trouble finding the correct hostname (security.cloudflare-dns.com) to use with the malware filtering. CF’s docs suggest 1dot1dot1dot1.cloudflare-dns.com is required, which is for 1.1.1.1. without filtering. Using that hostname with one of the filtering options doesn’t work with DoT. Problem solved. [In other words, it appeared only one of the pre-configured options would work with DoT].
Both of these need to be manual entries in WAN/DNS-over-TLS Server List:
# # Cloudflare Security servers
Address 1.1.1.2
TLS Hostname security.cloudflare-dns.com
# # Cloudflare Security Alt servers
Address 1.0.0.2
# # Cloudflare Family servers
Address 1.1.1.3
TLS Hostname family.cloudflare-dns.com
# # Cloudflare Family Alt servers
Address 1.0.0.3
For IPV6 use Address:
2606:4700:4700::1113 and 2606:4700:4700::1003 or 2606:4700:4700::1112 and 2606:4700:4700::1002
Address 1.1.1.2
Address 1.0.0.2
Address 1.1.1.3
Address 1.0.0.3
Sorry to bring this out from old times. Are there TLS hostnames for IPv6 addresses?
2606:4700:4700::1112 and 2606:4700:4700::1002 are not on the list.
Looks like you'll have to enter it manually.
# nslookup security.cloudflare-dns.com
Server:    127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 1.1.1.2
Address 2: 1.0.0.2
Address 3: 2606:4700:4700::1112
Address 4: 2606:4700:4700::1002
