Question #1: Should I start a new thread for this topic or not?
Well, I appear probably to have made a mess of setting up my RT2600 for the second time, because I realize that after setting up the RT2600, the settings made within the Actiontec router are still active presumably, because the Synology router is used as Access Point, all main router settings are done by the Actiontec router.
(And just so readers of this post have all the info they need: I have Verizon FiOS and the Actiontec is connected to the ONT via COAX cable and so must remain in the mix because I live on the third floor of a townhouse and pulling ethernet cable from the ONT which is on the ground level, attached to the back of the house would be an enormous amount of work).
Here’s what I did the second time I set up for the RT2600:
I connected an ethernet cable from an Actiontec ethernet port to the RT2600 WAN port.
As I stepped through the RT2600 setup windows, the first choice I made was to choose Wireless Router for Operation Mode and Wireless AP for External Access to SRM.
Question: I believe what I should be aiming for is to have the Actiontec be (and I don’t know the correct terminology to use here) the pass-through device, so that all the settings (firewall, assignmennt of IP addresses to my laptop, iPhone, iPad, wife’s laptop, etc.) are done by the newer and better RT2600 and not the Actiontec.
Does this make sense? Is this better/wiser than setting it up as I did?
I welcome any advice on this.
As a FIOS customer for 12 years, I have used a separate router plugged into the MI424WR Rev I, occasionally. No problems. But if you or your occupants are heavy gamers, or use certain VOIP(voice ) systems, there could be problems from both routers doing NAT services, a condition called 'double nat.' Hopefully this won't affect your situation. Also, you usually want to "turn DHCP off" on the secondary(synology in your case) router.
It's difficult to get rid of the fios router for several reasons. Most installs in houses use the coax port, rather than the lan port on the ONT(the white or black box where the fiber optic comes in from the street). The fios router must be connected to your coax system in order to do your TV menus & guides correctly.
If you don't have fios tv, and your install is using the lan port of the ONT, then you can use any old router. No problem. Have for years. But, first you must go into the annoying menus of the fios router and press the 'release dhcp' button,' then pull the fios router power cord. Or call verizon tech. A new router will automatically 'renew' the dhcp lease. Just in case you get rid of the fios router.
Your fios router is old tech, verizon can use it to snoop on you(but they don't), but remarkably trouble free. It's not too secure, but as you said, you will be relying on the synology for security. Should go well.
good work! I just love it when these things work.Thanks. Have been up and running, trouble free, for almost two months now and so far, no problems.
Thread starter | Title | Forum | Replies | Date |
T | Synology will try to lock you into using their branded drives | Synology | 4 | |
Synology DS918+ doesn't start with the drives in | Synology | 9 | |
B | Synology DSM Version: 7.2.2-72803 (2024-08-26) | Synology | 1 | |
O | Upgrade Synology DS718+ from 2 GB to 16 GB | Synology | 1 |
Welcome To SNBForums
