giladgaron
I want to add wireless N capabilities to my existing network and I would like some advice.
Network setup:
WAN: 10mbps ADSL.
Wireless Router: Linksys WRT54GL 1.1 running DD-WRT 2.4sp1
Clients:
I want to connect my HTPC to a wireless N network, The way I see it, I have two options:
1. replace my current router with a new dual radio/band wireless N router and buy a wireless N network card for my HTPC.
2. buy a cheap wireless N router/access point, connect it to my router via Ethernet as an access point and use only my HTPC with it (with a wireless N card) .
I have a couple of questions:
1. I prefer going with option number 2 since it's cheaper and because the range of wireless N router in my country is limited.
Do you think it's a good solution?
2. If I go with option number two, will my current router be able to deal with all the traffic? my HTPC which online all the time doubles as a bittorrent client.
Thank you for your advice.
Network setup:
WAN: 10mbps ADSL.
Clients:
- PC, connected via Ethernet, my main pc, used for gaming and surfing
- HTPC, connected via wireless G, doubles as a download server
- Netbook, conneted via wireless G
- Playstation 3, connected via wireless G
