I've read a number of threads regarding RAM usage and Adguard Home with no real consensus on a good way to reduce the memory footprint.
I'm on GT-AX6000 fw388.1 and using Adguard Home (Edge) with the default install from AMTM (also unbound with the defaults as the upstream)
When I do a reboot, the router is at 59% RAM utilization, which I'm fine with. As soon as I access the Adguard Home web interface, the RAM jumps to 97% and stays there forever. Although it doesn't seem to cause any performance issues, 97% mem utilization sounds like a lot and I'd like to try to reduce it.
I also have a 2GB swap file on USB, however it doesn't seem to get used. I noticed /proc/sys/vm/swappiness was set to zero, so I changed that to 60, but it didn't seem to help matters....Also, it goes back to zero on a reboot. Anyone know why?
