AdGuardHome AdGuardHome Blocklists
What's going on with the Spider-Man router? Missed the target and fell from height?
My router resembles a "facehugger"... does that count?
I don't know what you guys are talking about.
Were you both staring at the Sun for too long on April 8th? 🧐
Hello, so with the Hagezi lists I'm noticing there are now some lists that have the standard DNS AdGuard list and IP list. For example, The Threat Intelligence Feeds list and DoH/VPN/TOR/Proxy Bypass. Although the description says the IP list is to be used in conjunction with the DNS list how do they differ in terms of:
Speed/Efficiency
Effectiveness
I currently have too many lists (memory and CPU power is not an issue). I have tried enabling/disabling lists, but it has not made any noticeable difference. So trying to understand if there are any gains to be had by disabling or keeping the IP list. Should one list (DNS vs IP) be preferred over the other?
I am running unbound. Would that have any issues with too many DNS filter lists?
Speed/Efficiency
Effectiveness
Personal preference.
I use all the lists (hostname and IP).
  • Like
Reactions: Zim
Some lists (like OISD Big and Hagezi++) include many other lists. Adding those lists is a waste of memory and cpu.
I have 4 DNS Blocklists configured, how are they evaluated, AdGuard DNS filter first, then HaGeZi Threat, etc. or all of them are combined and then performed a single scan? Thanks
My lists are:
- AdGuard DNS filter
- HaGeZi's Threat Intelligence Feeds
- HaGeZi's Pro++ Blocklist
- OISD Blocklist Big
My lists are:
HaGeZi's Pro++ may cause some false blocks.
Old thread but sharing lists I use, in case others find it useful.
Note rule counts are always as of certain date.
1Hosts (Lite) - 88,802 rules
https://badmojr.github.io/1Hosts/
List for blocking pesky ads, trackers, and malware. Balanced version: set and forget, doesn't hamper user experience.
HaGeZi's Pro mini - 87,134 rules
https://github.com/hagezi/dns-blocklists?tab=readme-ov-file#promini
Size-optimised version for DNS/Browser adblockers. This list only contains domains from the Pro full that have been found on Top 1M lists (Umbrella, Cloudflare, Tranco, Chrome, ...) in the last 12 months.
HaGeZi's TIF mini - 94,218 rules
https://github.com/hagezi/dns-blocklists?tab=readme-ov-file#tifmini
A size-optimised version of the Threat Intelligence Feeds Medium list. Designed for Adblockers that have problems with the size of the TIF Medium list.
xRuffKeyz NRD Phishing 30-days - 8,634 rules
https://github.com/xRuffKez/NRD/tree/main/lists/30-day_phishing
NRD list useful for blocking recently registered domains, many of which are associated with malicious behavior, advertisements, or unwanted tracking.
OISD Big Safe Top-N - 121,874 rules
https://github.com/cbuijs/oisd/tree/master/big
Optimized version of OISD Big blocklist. Safe list, suggested excludes removed. Domains actually used according TOP-N lists.
OISD NSFW Safe Top-N - 68,734 rules
https://github.com/cbuijs/oisd/tree/master/nsfw
Optimized version of OISD NSFW blocklist. Safe list, suggested excludes removed. Domains actually used according TOP-N lists.
My Adguard plugin filter lists working inside OPNsense+Unbound and I work 100% from home over Cisco Anyconnect using a dual pipe for non-VPN and VPN traffic to Zscaler and never had a site misbehave, important in the financial industry I work in.
Probably some duplication, but Adguard takes care of that.
