I am a computer / networking guy and I would love to see 10G over Copper for the home and I am sure we will see it eventually, it is pretty common place these days in the Data Center along with 40G but it will be sometime before we see it come down in price enough to be even remotely affordable.
I do a lot of photo / video editing and with today's SATA 3 Drives and SSDs it is simple to saturate a single gig link and while Link Aggregation is very common and supported on even some relatively low end switches it doesn't work how most would like it do. Even with the new SMB Version 3 which supports Multi-Path you aren't going to get more than 1G over a your multi-link connection / file copy unless you breakup your file copies in to multiple file copies which will then create different connections.
So since I don't see this changing anytime soon the only way to get faster network file copies is to get faster links and 10G would be awesome. I looked in to it before buying my Synology but realized we just aren't there yet and probably won't be for the foreseeable future. So I opted for a regular version with 4 ports in a LAG Group, sure it load balances but as mentioned above only a single TCP Connection so only 1G Max.
That said I do agree that 10G is way overkill for the "Average" user. Most people are thrilled with their Wireless G Wireless and that is fine for them but there are a lot of power users out there that wireless will just never be an option even with the newer standards out / coming out you still need the wired uplink to support it or at least other devices that will support it.
No. This is not a money issue nor is it a demand issue once you sell them at a reasonable price there will be a demand for it! Yes they can be produced at the same rates that 100MB nics were some 10 years ago or even at the rates that 1GB nics are now they might not be as profitable but, they would still be profitable! Tell me that a 10GB nic should cost more than a motherboard with all of its interconnects and so forth and I will call you a liar! It does not cost more to make period end of discussion. The solution is really simplistic do a run of reasonable 10GB equipment for consumers at a reasonable price and then stop see what happens instead of saturating the market with 10GB equipment marking it way up until the price falls I assure you it will fly off store shelves once people catch wind of this affordable device.Follow the money. If there were significant demand for 10GbE, manufacturers would produce the products, but there is not.
The use cases cited are niche, not mainstream. The average consumer is mostly wireless and going moreso.
The cheapest way to get 10G is by using a managed switch with a motherboard with 2 gigabit ethernet + 2 Intel quad port server NICs. I once got a 2nd hand intel quad port server NIC for £25 and it was low profile. You will need 10 cables though and another 10 cables somewhere else. So for more devices you'll need more quad port NICs and larger switches or perhaps switches with stacking capability. Really shows how the prices havent improved. By the time we need 10G inflation would've taken over and 10G would be worth the same as 1G is now.
Quantenna Rolls Out 10 Gigabit Wi-Fi
Note Freescale's reference design
Honestly I see the fractional implementation of 10Gbe getting traction in the home before 10Gbe itself.
IE. 2.5 and 5Gbe.
There are four reasons they are going to be pushed as "needed" instead of 10gbe
First off is the Wave II AC devices will be pumping more data than a 1gbe line can feed but not so much it will saturate 10Gbe.
Second NBaseT uses Cat5e and Cat6 cables which are far cheaper and easier to work with compared to Cat6a.
Third, NBaseT is not a competing standard to 10Gbe. It is designed to be backwards compatible all the way to 10BaseT
Fourth, the hardware is cheaper if the manufacturer designs it to negotiate at only the lower rates.
Side point; Cat7 and up are not ratified standards and thus a manufacturer can sell you Cat3 cables at Cat7 and it will be legit. It is just their definition of Cat7.
As an interim solution being used in businesses today that is applicable to power users at home;
Etherchannel/Port Trunking/LACP/SMB3 Multichannel
There are a ton of names and implementations but it comes down to using more than 1 cable to link a device to the network.
2 cables = 2Gbe
4 cables = 4Gbe
Correct, best you can get is 1gb/s per device.Etherchannel/Port Trunking/LACP/SMB3 Multichannel
I have this implemented in my network from my various systems to my Synology NAS and all it does / will do it load balance. You will not / can not get more than a single Gig of bandwidth per TCP Connection. This is only good for multiple TCP Sessions and even SMB3 / Multi Channel isn't working for a single file copy as of yet. This is one of the main reasons I would love 10ge as it is a single port and a single tcp connection would be able to use the full bandwidth.
Well, to add to that, Thecus does sell NAS like devices running windows storage server 2012To add since you mention a NAS, SMB3 itself does not support SMB Multichannel, ONLY Windows 8, 8.1 and Windows 10 implementations of SMB3 and 3.01 support SMB Multichannel.
No other vendor supports SMB Multichannel in SMB3 (and no one else is using 3.01 yet). So you can only do it between Windows 8, 8.1, 10 and server 2012 machines. If you are connecting to a NAS, you will only get 1Gbps of throughput.
Sorry, lazy and I don't feel like reading over the extremely lengthy posts (not that they might not be worth reading).
A 10GbE ROUTER, is going to be massive money. Up in the many thousands of dollars range. A 10GbE internal network with a 1GbE router that can actually handle 2Gbps of full duplex routing is a better option and not terribly pricey.
For a 10GbE internal network, what kind of distance and how do you want to set it up? You can use SFP+ and Twinaux SFP+ modules which tend to run about $75 for a pair of cards with 10 meters to Twinaux.
Thread starter | Title | Forum | Replies | Date |
A | Help needed with used QNA-T310G1S | Switches, NICs and cabling | 0 | |
H | HP V1910 - fan needed in room temperature? | Switches, NICs and cabling | 6 | |
Type of fiber adapter needed with this?? | Switches, NICs and cabling | 4 |
Welcome To SNBForums
