Aegis Aegis 1.7.x
Could you explain to me what that last command is showing? "grep -F aegis /var/log/log-message | tail"
Sure,
grep -F aegis /var/log/log-message searches for lines with the text “aegis” in the file /var/log/log-message, that is where the system logs events (in particular iptables log events).
tail is showing only the last 10 lines of the piped request (the grep… one).
Thanks. So its not showing anything nefarious going on, right?
No, it shows what should be in the aegis log, here:
Many connections attempt blocked by aegis from LAN device 192.168.1.129 to WAN 10.201.126.241 and 192.168.11.1
Hey HELLO_wORLD, I apologize for not getting to this sooner, but had some family issues to contend with here. Anyways, attached is the text file of the output you asked for. Hopefully it is all there, if not let me know and I will run it again. Thanks for taking a look at it whenever you get a chance, appreciate your help as always!
You got it right, thanks.
For some reason, the aegis log file is empty.
While aegis is up, do you have the file /tmp/aegis-logd.awk, and what is in it?
Also, do you see a fifo node /tmp/aegis-logd?
ls -lt /tmp/aegis*
cat /tmp/aegis-logd.awk
root@R9000:/$ ls -lt /tmp/aegis*
prw-r--r--    1 root     root            0 Jul 21 10:11 /tmp/aegis-logd
-rw-r--r--    1 root     root         1557 Jul 21 08:35 /tmp/aegis-logd.awk
-rw-r--r--    1 root     root           32 Jul 21 08:35 /tmp/aegis_status
I do have the cat /tmp/aegis-logd.awk, but for some reason I am having a hard time trying to post it here.
The ls looks ok, BUT, the awk file size is 1558 for me, so could be the problem!
What if you do aegis down; rm /tmp/aegis-logd.awk; aegis up
Thank you!
Sorry, I am not very present/available lately.
So the file is ok, the 1 byte difference is only router’s name between yours and mine.
Anyone else experiencing the same issue as @foo man ? Particularly R9000 users? Or is he the only one?
R9000 here...nope no issues. Logs and date stamps running normal
Thanks @Jauger
So it is more related to @foo man specific setup.
I think it might be buffer related.
Maybe try:
aegis down
rm /tmp/aegis*
aegis up
Will think about it.
Ok @foo man
Let’s figure out first if anything is sent to the pipe.
With aegis running and log enabled, can you run this command and wait a little bit to see if it displays anything or not:
cat /tmp/aegis-logd
Thanks HELLO_wORLD. Sorry really don't want you to waste too much of your time on this. One of these days I'll just wipe out all my settings in the router and reset them to see where/if it happens again. But in the mean time here is what I'm getting with that command. There is a lot more but this is a snippet:
240947:[wifi1] FWLOG: [112513531] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
240956:[wifi1] FWLOG: [112522747] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
240959:[wifi1] FWLOG: [112525819] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x4, 0x0 )
240960:[wifi1] FWLOG: [112526843] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
240988:[wifi1] FWLOG: [112555163] RATE: ChainMask 3, peer_mac aa:e, phymode 5, ni_flags 0x00201006, vht_mcs_set 0x0000, ht_mcs_set 0xffff, legacy_rate_set 0x6b574bf
240988:[wifi1] FWLOG: [112555199] WAL_DBGID_SECURITY_UCAST_KEY_SET ( 0xaa0e, 0x0 )
240988:[wifi1] FWLOG: [112555199] WAL_DBGID_SECURITY_ENCR_EN (  )
240988:[wifi1] FWLOG: [112555199] WAL_DBGID_SECURITY_ALLOW_DATA ( 0x448bdc )
240988:[wifi1] FWLOG: [112555468] WAL_DBGID_TX_BA_SETUP ( 0x448bdc, 0xaa0e0006, 0x2, 0x20, 0x1 )
240988:[wifi1] FWLOG: [112555468] RATE: ChainMask 3, peer_mac aa:e, phymode 5, ni_flags 0x00201006, vht_mcs_set 0x0000, ht_mcs_set 0xffff, legacy_rate_set 0x0000
240993:[wifi1] FWLOG: [112560770] WAL_DBGID_SECURITY_UCAST_KEY_SET ( 0xaa0e, 0x0 )
240993:[wifi1] FWLOG: [112560770] WAL_DBGID_SECURITY_ENCR_EN (  )
240993:[wifi1] FWLOG: [112560770] WAL_DBGID_SECURITY_ALLOW_DATA ( 0x448bdc )
241004:[wifi1] FWLOG: [112571901] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
241013:[wifi1] FWLOG: [112581117] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
241014:[wifi1] FWLOG: [112582141] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
241027:[wifi1] FWLOG: [112595453] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
241030:[wifi1] FWLOG: [112598526] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
241042:[wifi1] FWLOG: [112610814] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
241052:[wifi1] FWLOG: [112621054] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
241056:[wifi1] FWLOG: [112625150] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
241079:[wifi1] FWLOG: [112648703] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x2, 0x0 )
241085:[wifi1] FWLOG: [112654847] WAL_DBGID_XCESS_FAILURES ( 0xffff, 0x3, 0x0 )
Ok, this means that the aegis log daemon is catching the logs.
However, it does not process what it catches, and it is probably because there is too much going on in the logs:
Your logs are spammed with these wifi1 error logs. There is something going on with your setup.
