AI-MESH with Multiple GuestNetworkPro - Auth Failure on AX86U_Pro
Ah, beta firmware!
Did they tell you that they fixed anything else?
It doesn't fix a main WLAN leaking WPS from node.
OE
Seems to have fixed the Wireless MAC Filter not working on Guest network. At least the pesky Tuya Smart device somewhere in my neighborhood is not trying to access the router with Guest IoT enabled.
Have you reported this?
No, I have sort of been waiting to see if someone else here confirms same and/or if it goes away on its own or with the 'March' update to VLANs (which now seems to be delayed).
OE
